help needed, installing autometer gauges
Old May 16, 2007 | 09:23 PM
vette4820's Avatar
vette4820
Default help needed, installing autometer gauges
I'm current installing autometer gauges in my 76. I'm not the greatest with wiring and need a little help. First, the tach has a 3 prongs on the back. The original tach had 3 prongs, but the 3 wire plug is not set up in the same order as the autometer tach. Do I need to re-wire the plug so all three prongs line up correctly? The top prong on the tach does not line up with the top slot in the plug. Also, the original volt meter has 2 power wires (one black and one black with a white stripe). Do I wire both of these up to the positive post on the new gauge and then wire up a separate ground? That's the only thing I can think of. Thanks for any help you can offer.
Old May 16, 2007 | 09:36 PM
rosslato's Avatar
rosslato
all yours questions should be answered here
http://earchitect.50megs.com/corvette/install.zip
