70 Brake Calipers
Old May 17, 2007 | 07:35 AM
HJVet's Avatar
HJVet
Default 70 Brake Calipers
Hello, Newbys to the 1970 Vet. Would appreciate your experience. Leaking Calipher. Specifically, how would we know if we should rebuild or buy new? I have read a lot of post, but guess I need specifically how to check for corrosion, and on what exactly.
Appreciate you time.
HJ
Old May 17, 2007 | 08:32 AM
Duke94's Avatar
Duke94
You'll be $$$ ahead if you buy rebuilt with SS sleeves and O'ring seals. Much improved over stock setup and will last a long time.
http://www.vbandp.com/
Old May 17, 2007 | 09:55 AM
Bill Z's Avatar
Bill Z
Just like Duke said. You will be better off with rebuilds with stainless inserts. Then they will never corrode again. If you buy the regular rebuilt or rebuild them yourself, the corrosion will just return in short order.
My additional suggestion is to replace the break hoses that connect the calipers to the break lines. Just a thought.
Don't take chances with your breaks.
Old May 18, 2007 | 06:49 PM
HJVet's Avatar
HJVet
Thanks ! Appreciate you reply
HJVet's Avatar
HJVet
Appreciate you agreement! Thanks Guys.
Old May 18, 2007 | 08:38 PM
72LS1Vette's Avatar
72LS1Vette
If you don't know the history of the car you might already have sleeved calipers. Remove the leaking caliper and seperate the halves. The pistons and seals come out pretty easily. If the bores are rusty and pitted you do not have stainless sleeves. If the bores look good you might see the edge of the sleeve at the bottom of the bore. You can either rebuild with stock parts for ~$13.00 / caliper or buy O-ring kits from VB&P for more $. The O-ring seals are a better design and will prevent air entering the calipers because of excessive runout in the rotors.
If you need to buy a sleeved caliper you can get them at Autozone or you can get O-ringed calipers from VB&P.
Rick B.
Old May 19, 2007 | 09:47 AM
71406's Avatar
71406
I purchased new calipers from Lonestar. http://www.lonestarcaliper.com/
Lonestar is the only licensee that can make brand new castings for the 1965-1982 corvette using the Delco Moraine logos. I've used rebuilt calipers from other companies and twice has to return them...while they were still under warranty, I got tired of replacing. New Lonestar calipers may cost a little more, you can sell your current calipers for cores to help offset the cost. With a rebuilt set, you will need to exchance your cores.
Good luck.
To 70 Brake Calipers
