Can anybody help me identify my rear axle/differential? I have been looking on the internet but have not been able to find anything.
I found the following data on it:
2 AZ 11 8 67W
2=2nd shift
AZ=3.55 heavy duty(big block) positraction
11 8 67 - sure there isn't another number there?
Month was a 2 digit number, so January would be '01' etc
Day had a 2 digit also ... sometimes.
January 18, 1967 ?? ... for a 1967 Corvette
November 8, 1967 ?? ... for a 1968 Corvette
(Both '67 and '68 Corvette used the same AZ 3.55HD code)
I suspect, if they're spaced as you indicated, it is the Nov 8 date.
If the car was built Nov. 67 then it is a 68. AZ code was not used in 68 so, I would say it aint the one that came there. You never said that it was a 68.
thanks for the quick answers both of you ... hmm my car was assembled in november '67, can this differential be the car's original? I have a not original 327 cui with a fake big block restamp number on it, in my car now.
Are there other ways to check if my car was originally a big block?
Yes, there's a very good chance it is original to the car ...
The date coincides with a later November build (my original rear has a date 2 weeks before the car build date)
The AZ code (3.55 heavy duty big block positraction) was used for 1965-66-67-68 & 69.
To check if the car was a big block .... ???
what is the tach red line?
is there a rear sway bar??
out of curiosity, what is the fake restamp number??
That` ill teach me to rely on the books. The GM parts book did not list the AZ in 68, but upon further review, it does show back up in 69. So, I guess it might just be in 68 also.
