I am looking for help choosing the appropriate stall for a 406 in a 77 vette with a stock thd350 and 3:08 gears. Most vendors I talk to recommend a 2000 - 2400 stall. This seems small for a 406 but with 3:08 gears it will be turning 2500 rpms @ 65 mph.
If I go with a higher stall for a better launch will I cause slippage and overheating when driving around town? This will be a strictly street driven vehicle. The desktop dyno shows Max TQ of 506 @ 3750 RPM and Max HP of 475 @ 5500 RPM. The desktop dyno does not show TQ below 2750 RPM's. At 2750 the TQ is 485.
With ANY higher than stock stall converter you should install a transmission cooler. If your car is strictly street, you will be happy with a 2000-2400 stall. These are usually 11" converters, and are very efficient even with stock gearing. You will not not notice slippage different from stock when driving. Higher stalls (around 3000 or more), however, are noticeable around town (slippage) and are best suited for steeper gears. The performance gain is noticeable, but best suitable for occasional drag strip runs.
No minimum operating temp on an auto, the lower the netter. Either use a powered cooler or a heat sink type. Keep it as cook as possible.
The higher stall will not cause more slippage, it will slip more bt design, but not cause you to over heat around town
If I have a 2400 stall and I am traveling 40-50 mph in 3rd gear @ 2000 rpms will this cause problems? Is this the point where it will experience "slippage by design". What is the impact when you are driving and "slippage" occurs. Does the slippage increase heat and is that why you need to add a cooler. I am trying to find the right balance. between performance and driveability.
I just want a stall that is noticably better than stock and will allow the wheels to spin. Since the 406 is being built to be tourqey anyway is a 2000 sufficient for a good launch? I only have access to torque convert when I make the swap to the 406. I want to make a wise choice.
Called TCI and they recommended a Breakaway converter P/N 240900. Should be around 2200 - 2400 stall.
Anyone with experience / opinions on this converter?
Yes, I used this converter before my present Art Carr. This is an excellent street converter. Stalled at around 2400 rpm in my 383, and is very efficient. NO noticeable change (slippage) from stock when cruising. As for 2000 rpm cruising with a 2400 stall converter.....your car doesn't sit still until "stall speed", but moves at at low rpms as you accelerate; to this extent, ALL converters slip regardless of stall. Unless you have a lock-up converter, it is ALWAYS slipping to some degree, even at top end. More efficient converters just slip less. Your 2000 rpm cruising may not be noticeably different with the new 2400 stall than with the stock converter. At 2000 rpm, the TCI was about moving my car about 1 mph slower than the stock converter did.
www.PTCRACE.com
They have the best stalls that move just fine on the street, and when you stomp the gas its like popping a clutch!
Im going with a 10 inch 3500 for the street, Ive had 3 of them and they work great!
Most of the tc are rated for a 350, more torq means higher stall. In my Formula I have a 355, 3.73 rear with a 700r4 running a 2800 stall and it bits at about 3000 because of the higher torq from 700r4 first gear and 3.73 gear. Your 400 will stall higher than a 350 for sure.
I'm running a 700r4, 3.08 rear, and a 2000 stall on my 406. It slips a bit more than stock and it is noticeable especially if you hit it hard. I'm happy with the way it performs and I intend to drive it around town which is why I went with a lower stall. I wouldn't recommend a large slip unless you're racing.
Based on your experience do you think 2400 stall with 3:08 gears is too much for the street. Will it slip to much when driving 45-50 mph in 3rd? I think it will be fine at highway speed. I have a stock thd350 so the rpms are around 2500 @65 mph.
I am putting together the 406 to be very torquey. My goal is to be shoved back in the seat and spin the tires while still using the 3:08 gears. Is this a realistic goal with a 2000 stall
