p/s cylinder
Old May 17, 2007 | 10:13 PM
Hazz515's Avatar
Hazz515
Navigator
Default p/s cylinder
any idea how to get a power steering cylinder off from the ball joint? I have all p/s lines off the piston rod detached the nut off the bolt near tthe ball joint. I 've tried a jaw puller and a ball joint seperator and even greased it down with wd40. I even hit the bolt with a hammer it won't budge? any ideas? Cause I'm out of them. I've got the new cylinder and ready to install just that one stubburn part is making a twenty min job last forever? Please Help?
Old May 17, 2007 | 11:16 PM
wombvette's Avatar
wombvette
To release a taper joint put some pressure on it with a fork or a puller and whack the side with a hammer. Not the end with the threads, the side of the link where the hole goes though.
Old May 17, 2007 | 11:26 PM
MikeMc71's Avatar
MikeMc71
There is a tool for that, just about any parts store will have one.
Old May 18, 2007 | 12:59 PM
Hazz515's Avatar
Hazz515
Navigator
Thanks I hammered the crap out of it and finally got it loose.
To p/s cylinder
