ideas on high quality header gaskets
Old May 17, 2007 | 10:47 PM
realtoeman's Avatar
realtoeman
Cruising
Default ideas on high quality header gaskets
Sorry if this question is too simple but i dont want to guess at brand hype....what would you guys suggest for header gaskets?
Tnx
Toe
Old May 18, 2007 | 12:12 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
No question is too simple, no detail is too small.
Unless I hear a good case against them beforehand, I'm going to try a set of Mr. G's copperseals on my next installation.
http://www.mr-gasket.com/ProductDeta...inselection=2#
...with Stage-8 locking header bolts.
Old May 18, 2007 | 12:48 AM
Restorod '79's Avatar
Restorod '79
I saw these in Corvette Fever magazine. "Earl's exhaust seals" Has anyone used these or heard of their use?
Old May 18, 2007 | 01:17 AM
TheSkunkWorks
This is what I love about the forum. Haven't heard of them before, but very interested in learning more about them myself. Here's a link for applications...
http://www.holley.com/types/Pressure...er%20Seals.asp
Old May 18, 2007 | 07:49 AM
73BLWN's Avatar
73BLWN
I use Percy's Seal-4-Good. No more blown gaskets, or leaks ever. I even double stacked the gaskets on my blown sbc trail/mud truck to get a bit more spark plug clearance. One of my spark plugs that kept burning through my spark plug boot. I still never had a leak. Awesome!
Old May 18, 2007 | 07:50 AM
realtoeman's Avatar
realtoeman
Cruising
Default thanx all
Thanx all
Old May 18, 2007 | 08:15 AM
RHD '68 L89's Avatar
RHD '68 L89
U don't need no stinkin' gaskets.....
If your flanges are straight then just use Silcone. Been using it for years with no leaks.
Old May 18, 2007 | 08:27 AM
Edzred72's Avatar
Edzred72
I have used Percy's soft aluminum header gaskets on two cars and they "seal for good". The soft material crushes a tiny bit, and forms around the header & exhaust ports to produce a blow proof seal. Also available in copper (more $) but Percy tech said copper is more for higher heat producing performance motors.
Two header bolts on mine loosten'd to finger tight...still NO LEAK
Eddie
Old May 19, 2007 | 05:36 AM
MCMLXIX's Avatar
MCMLXIX
I have used the Earls gasket and find they work well.
Check the bolts a few times and they are good for years.
The only fault is the price.
Old May 19, 2007 | 07:05 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
That and dissassembly, they are definetly not reusable. The replacement inserts cost more than a good quality gasket. Ron B.
Old May 19, 2007 | 07:55 AM
Tim H's Avatar
Tim H
If you can't get MR Gasket ultra seals and some gasket sealer to seal then you have a head or header problem!
That high price stuff is just a band aid for a real problem.
I have never had a header gasket leaking problem like some people do all the time for some reason?
Old May 19, 2007 | 08:08 AM
theandies's Avatar
theandies
Percy's or Earls. The best period. If you buy anything else you'll just be buying them again and again and again and again and again...........
I safety wire my bolts but there are many types of locking bolts. Get yourself a Summit or Jegs catalog or go to their websites.
Old May 19, 2007 | 08:44 AM
Jims79's Avatar
Jims79
Copper or Aluminum the only way to go. no leaks ever. I even have the metal gaskets between the headers & exhaust pipes. nothing sounds worst then an exhaust lead from a nice exhaust system.
Old May 19, 2007 | 08:51 AM
MIKER's Avatar
MIKER
Another vote for Percy's.
I had a difficult time sealing my round port Headman headers to the “D” port TrickFlow heads. I tried several different types but the gasket that finally worked for me was the Percy’s seal-for-good round port aluminum gaskets.
http://store.summitracing.com/partde...5&autoview=sku
Old May 19, 2007 | 11:34 AM
a1sensei's Avatar
a1sensei
I just use the copper ones they have lying around at Advance Auto Parts. About $50 and never any problems. God bless, Sensei
Old May 19, 2007 | 11:38 AM
Tim H's Avatar
Tim H
$50 for header gaskets????
I used the ones that came with the $89 headers, no sealer or anything and they haven't leaked or come loose!
Its kind of funny , its just a cheap small block Chevy,but put it in the high and mighty vette and it turns into the highest maintance, only the best will do money pit!!!
Old May 19, 2007 | 11:58 AM
chuck d's Avatar
chuck d
I used to get about two or three seasons out of old style white header gaskets. I tried soaking them in water before I installed them, that didn't work. Somebody suggested I try Grey colored Felpro #1426 header gaskets (#1426 is the number for O-Ring flanges). They were cheap and have been leak free for a few years now. I might add,you should also check your header bolts frequently for tightness
To ideas on high quality header gaskets
Old May 19, 2007 | 02:03 PM
C3 Stroker's Avatar
C3 Stroker
I have Felpro #1404 (for my application) and they have never leaked. I re-tightened the header bolts after the first 2 weeks use and they have remained OK for years.
Old May 19, 2007 | 04:27 PM
SteveG75's Avatar
SteveG75
I use the Mr Gasket Ultraseals and have no problems. A thick, flat header flange is much more critical to good sealing. I have blown out the Percy's gaskets by overtightening cheap headers and warping the flanges.
Old May 19, 2007 | 05:46 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I went through 3 sets of cheapies in one season, 3 different types. If you drive the car the way it's intended you WILL blow them out. I am also looking for something better and will
