Another carb question
Old May 18, 2007 | 03:01 PM
78L-82's Avatar
78L-82
Default Another carb question
After the car has been run for an hour (typical daily commute) and parked for 3-4 hours, when I go to restart it, it barely keeps an idle and I have to give her a little gas to keep running. After a few minutes all is well.
Could I have a bad choke or accelerator pump?
Old May 18, 2007 | 03:29 PM
BigBlockk's Avatar
BigBlockk
Sounds like it is boiling the fuel out of the carburetor. What year are we talking about.
BigBlockk
Later.....
Old May 18, 2007 | 03:48 PM
78L-82's Avatar
78L-82
1978 L-82 with Q-Jet M4MC.
Old May 18, 2007 | 04:16 PM
...Roger...'s Avatar
...Roger...
If the choke works good in the morning then it sounds like its not reengaging after its slightly warm.Try rotating the choke a little tighter.
Old May 18, 2007 | 06:18 PM
marshrat99's Avatar
marshrat99
The other possibility is that the carb might just be a little on the lean side at idle. Turn BOTH idle mixture screws out 1/4 - 1/2 turn and see if it helps. Not that a Holley SA is the same carb as the Q-jet but my SA always behaved like yours until I rejetted the carb and had to adjust the idle mixture. Runs great now during warm up and after sitting like yours.
To Another carb question
