Mono leaf Spring
Old May 18, 2007 | 05:37 PM
eagle77's Avatar
eagle77
Cruising
Default Mono leaf Spring
Hi from France
Got problem with my mono leaf spring it just broke today and i don't know why ?
Is it possible that it is to near from exhaust system ?
Thank's for your help
Old May 18, 2007 | 06:21 PM
73VetteKS's Avatar
73VetteKS
Hi France. Yes, it is possible that your exhaust is too close to the spring. The mono-spring I installed failed after about 2 years. Luckly it broke when I was about a half block from my home and only going about 25mph. I heard a very loud bang, much like a shotgun, and then rear dropped. The spring broke on one side near where the exhaust pipe runs. It may have been at fault, because if I had looked at it earlier, I would have noticed the black rubberized coating was wrinkling because of the heat. The pipe wasn't touching, but it probably was no more than 1/2 inch of clearance.
I then bought a TRW spring that had a heat-shield. It has been on for about 12 years and 120,000 miles, with no problems.
-Jim
Old May 18, 2007 | 06:40 PM
72 LT1's Avatar
72 LT1
Heat shield is good idea, and keeping exhaust 3 inchs away from unsheilded glass spring is also recomended.
Old May 18, 2007 | 07:46 PM
WESCH's Avatar
WESCH
Salut
Or change to side pipes.
Regards from Luxembourg.
Günther
Old May 19, 2007 | 03:44 PM
eagle77's Avatar
eagle77
Cruising
Hi
Many thanks. I'm going to look for a TRW.
See you
Eagle
Old May 19, 2007 | 05:15 PM
69 Convertible's Avatar
69 Convertible
Can you buy heat shield for the spring by themself?? Or what can you use for a heat shield? Tony
Old May 19, 2007 | 11:19 PM
73VetteKS's Avatar
73VetteKS
I'm not sure if you can buy just the heat shield, but you could make one. It is basically a piece of thin sheetmetal that bolts between the spring plate and spacer, and extends about 8 to 10 inches on each side, and about 1 inch front and rear. The spacer between the spring and spring-plate on my setup is about 1/2 inch thick, puting the heat-shield about 1/2 inch below the spring. My exhaust is about 1/4 to 1/2 inch below the heat-shield. Sorry I don't have a pic.
With 2 1/2 exhaust stock exhaust, three inches of clearance is not possible. At least not on mine.
There is a sample on Muskegon Brake web in hte Suspension section.
http://www.muskegonbrake.com/
Old May 20, 2007 | 04:53 PM
eagle77's Avatar
eagle77
Cruising
-Jim
Thank you. Someone tell me that it need long bolts with TRW spring for a corvette because the leaf is too bended .
Old May 20, 2007 | 08:29 PM
redwingvette's Avatar
redwingvette
It comes with a 8inch long bolt, Mine sits up about an 1/2inch higher now then it did with the old spring. My bolts on the old spring were 6-3/4inch long
To Mono leaf Spring
