Taking door panel off???
Old May 20, 2007 | 01:37 AM
ace69's Avatar
ace69
8th Gear
Default Taking door panel off???
I went to take off the inside of my 69s door panel and it seems it wont come all the way off with the lock still on...Is there a tool to remove the lock that I need..any info would be helpful thanks....
Old May 20, 2007 | 02:08 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
there is a clip that holds the **** on. a flat head should slide it out and off for you.
Old May 20, 2007 | 03:15 AM
ace69's Avatar
ace69
8th Gear
Thank you so much...... I really appreciate it
Old May 20, 2007 | 04:01 AM
69 Convertible's Avatar
69 Convertible
Don't forget the 2 philips screws on both ends of the door. The lower part of the door. It holds the bottom of the panel on. The tool for the clips for the door lock and the window crank
( if it's not power window) can be bought at an auto parts store.
Tony
Old Jun 14, 2022 | 08:58 PM
TerryConverse's Avatar
TerryConverse
Default Corvette 1967 Roadster Door Panel removal
Tony
Hello,
Is the window crank removal tool required if you have power windows?
Thanks,
Terry
Old Jun 14, 2022 | 10:49 PM
Eliredandblack's Avatar
Eliredandblack
You should do yourself a Hugh favor and spend some time looking at pictures and how to instructions, it easy to break things and in most cases the restoration parts are the same. Buy a Chevrolet Service Manual for your model year, also get a bunch of vendor catalogs, they have very good illustrations and will help you see how assemblies are put together.
Old Jun 15, 2022 | 09:01 AM
kansas123's Avatar
kansas123
Originally Posted by TerryConverse
Hello,
Thanks,
Terry
Nope
To Taking door panel off???
