Brake Calipers! Need a good set.
Old May 21, 2007 | 06:59 AM
sommerfliesby's Avatar
sommerfliesby
Default Brake Calipers! Need a good set.
A couple years ago my front calipers went bad and I took them to a local guy for a fix. Now the rears are leaking and I'm planning on doing them myself, and I've got a couple questions.
First, is there any way at all to avoid the four-piston setup? I've heard they are a major pain in the a$$ to bleed, and a two-piston might be just as effective.
Second, where do I buy a nice set that will be reliable...as in NO LEAKING for the next couple years! I'm thinking stainless steel and not cast in China, if possible.
Any opinions would help, I appreciate it.
BTW, the car is a 73.
Thanks,
mike
Old May 21, 2007 | 07:33 AM
Durango_Boy's Avatar
Durango_Boy
First off, unless your calipers aren't stock, you have four piston calipers right now.
What's your budget? You can upgrade to aluminum Wilwood calipers but they cost a lot.
Old May 21, 2007 | 08:56 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
The cheapest way is to rebuild the stockers, new seals basically.
The better way is to buy Wilwood calipers, but they are $500 +
Old May 21, 2007 | 09:27 AM
White79's Avatar
White79
Does Wilwood offer a brake setup package?
Old May 21, 2007 | 09:54 AM
stock76's Avatar
stock76
Check out www.vbandp.com. They have kits and individual calipers. If you are changing the calipers, and the brake lines are a few years old I would recommend getting a kit and replacing everything. Thay way you won't be going back and working on your brakes again for a while. Also, buy a Motive pressure bleeder. VBP has a good price on them too. I have had the same VBP SS sleeved calipers on my vette since 1983 and have only had to rebuild the fronts once. Haven't had to touch the rear ones. I don't think you could beat that for reliability.
Old May 21, 2007 | 11:01 AM
sommerfliesby
Thanks guys. That vb&p site is pretty good with the prices...I don't want to break the bank...are the Wilwoods $700 PER caliper?
To Brake Calipers! Need a good set.
