I'm not sure if this is a timing problem or a carb problem or a combination of both. 290hp crate motor, edelbrock 600cfm. First off, after the car has ran and then sat for a few minutes you have to pump it and it still acts like it's not getting fuel after a few seconds of cranking it will start and idle fine. If you turn it off and then start it again it will fire right up with no pumping needed. If you grab the throttle arm and floor it there is a hesitation. From a dead stop if you floor the car it won't even turn the tires over but as soon as you get going and floor it, it pulls hard.???
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I'm no expert ok,,lol but had similar problems in the past with new engine and a new edelbrock carb.
how old is the carb?
have you checked and/or disassembled the distributer, old ones can seize up and cause problems.
Timing ?? It can cause similar problems too.
Fuel pump ??,, very rare that these fail, but if you have an original gas tank/lines its probably very dirty and can cause fuel problems.
New plugs ??
Answers to these questions will help the experts on the forum to pinpoint your problem...good luck
Check The Fuel Pressure Those Carbs Run Best At 6 Psi. More Than That They Tend To Flood..i Use A Regulator Set A At 5.5 Psi. Runs Fine..you Can Download All The Info On The Carb On Edelbrock.com
Mine was jetted too rich. Went to number 11 on the chart. Seems to run a lot better.
I did notice when trying to set my timing that the line jumped around a few degrees. Could this cause my condition?[/QUOTE]
Make sure the sensor on the #1 wire is as far as possible from other plug wires, you will get interferance if rubbing on another wire. I could be way off but I would tend to look distributor, wires, plugs. Are you running points ?.
Also,, as stated above, these carbs are jetted rich,, so was mine,, and the floats are usually not set to specs.
do you still have the booklet that the carb came with ?? they have easy to follow trouble shooting,, maybe you can get it on there site.
To check the float level you remove the top of the carb and turn it upside down, the floats should fall to about the thickness of a #2 phillips from touching the top. just use the #2 like a feeler gauge to check. Also sounds like you might want to change the position of hte rod on the accelerator pump, it is at the front of the carb on the left side. When you push the throttle down this little plunger comes up and dumps a small ammount of fuel into the carb so it has enough to get going. I believe there are three holes so three possible settings. I agree withthe other guys that the fuel sounds like it is draining out of the carb after it is shut off, that would point to the fuel pump.
I wondered if the fuel pump was bad. It has a clear inline filter barrel type and I can see gas in it but it does'nt seem like much. should it be full of gas or is it ok?
had the same problem.edelbrock 600 cfm carb with dual plane intake.replaced the metering rods,and springs changed the squirt,then replaced the accelerator pump. if you call the edelbrock tech line they can help. they also gave me the accelerator pump at no cost
as Lars put it, 90% of carb problems are ignition problems. Since you already have two threads relating to your ignition timing and distributor I'd suggest getting your distributor problems fixed first, than get your timing set correctly, and THAN evaluate if you still have problems at that point that may require fooling with the carb.
