Engine Balancing Question for you guys....
So, I called up Isky and got a "piston notcher" that was supposed to fix the problem. Well, that tool is easy enough to use but for some reason, not matter how I used it, it would not cut the valve relief in the spot that needed more clearance. After a week of tinkering with that and getting nowhere, I finally broke down and took the Dremel and a carbide bit to the valve reliefs.
Believe it or not, to my amazement, this worked really well and cleaned up nicely. Now I'm trying to decide if I should have the rotating assembly balanced or not.
My pistons are already connected to my stock rods. So, I weighed each assembly separately on a postage scale that measures in 2 gram increments. The majority of the assemblies weighed in right around 1230 grams. Some were 1232, one was 1228; pretty much all within 2 grams though (remembering the scale won't do single grams). The only problematic ones were that one was 1236 and one was 1220 grams. I have no clue why one came in at 1220; it had very little material removed.
Anyway, I can't decide whether or not to have the whole thing professionally balanced at this point. I have a guy that can do it for about $200 locally but he can't get to it for 4 - 6 weeks. Then I have a guy about an hour away that can do it for $380 but can do it in a few days. They $200 guy wanted to get the pistons, rods, bearings, rings, and crank and make sure everything was right. The $380 guy just wanted the pistons, rods, and crank, nothing else.
A couple guys I have talked with say that for a street engine that isn't going to see 6000 RPM often and certainly not sustained that I should not be worried about it and just assemble the engine as is. Other people say it is a big deal and that I need to get it all balanced.
So, my question is for you guys that deal with this stuff more than I do, is what would you do?
A quick recap of the engine specs:
350 factory '81 block bored .030 over
stock crank ground .010 under
stock rods that have been checked at the machine shop
Clevite bearings all the way around
Trick Flow 23* aluminum heads
Performer RPM air gap intake
TRW Forged flat top pistons
Holley 600 CFM carb
Comp Cams XE274H cam
About 10:1 Static Compression Ratio
About 8.3:1 Dynamic Compression Ratio
I'm guessing somewhere around 400HP from the combo but that could be high or low; I won't know until it hits the dyno but have seen similar combos push 420HP.
Again, this is being built for the street and I'm just looking to do the right thing at this point. I'm willing to spend money where it needs to be spent but don't want to throw money and time away without good reason.
Thanks guys for any help with this decision.
BTW, $380 is ridiculous for that job. It is right at $200 locally as well.
Your's sounds to be rather far off. You are showing a 16 gram delta, which is enormous. So if you want to do the right thing, then you should have the rotating assembly professionally balanced. Funny thing is, it sounds like the cheap guy is trying to do a better job than the more expensive guy. However, it does seem a concern that neither one asked for the wrist pins (or spiral locks or wire clips, if you have them), since without them, you can't balance it correctly at all. Maybe they assumed by saying they wanted the pistons, that the pins were included, if so then OK. But just be sure they are included with the parts you take in.
Scott, he is not within 2 grams, he is showing at least 16 grams off, just on what he weighed. So who knows how far off things are overall. And GEEZ, VIZARD NEVER EVER SAID YOU COULD BE OFF 50 GRAMS PER PISTON. THAT WOULD SHAKE YOUR FILLINGS OUT. He may have said, 5 grams per piston for a budget build, but not what you claim. You should have your facts straight before you give advice, you could really screw someone up if they believed you.
- Do you have a old OE piston & pin you could weigh separately & post both here?
- What is P/N of new forged TRW? 2VR?, 4VR?, Trough? & what is oversize if any? Post it details here.
I had the original machine shop work done about 5 years ago and did not receive the original pistons back. At the time I figured that was fine because I didn't need them anyway. Now I wish I had them for comparison (lesson learned). I'm going to try and find info about the OEM ones online now to see what I can find.
Is Delta calculated by total difference or is it in relation to where the pistons sit on the crank. In other words, is it calculated between pistons 1 & 2, 3 & 4, 5 & 6 etc. or can be be any difference including say between 1 & 3? I'm just curious if their position changes this calculation.
I'll try and find the original specs and post them here.
When the proper balancing methodology is used, it makes no difference WHERE a particular piston/rod assembly sits in the engine, in relation to the calculation. The calculation used for the balancer bob weight, assumes the parts are weight matched. Which is part of the whole point of balancing in the first place.
Sure, I suppose someone could fudge things by juggling parts around, along with different bob weights on various journals, but Geez, why would anyone go to so much trouble to do something the wrong way. It would be less work to just do it right in the first place.
The bob weight on each rod journal is 50% of the reciprocating weight of 2 sets of piston/rod assemblies, plus 100% of the rotating weight of 2 sets.
There's an old saying, " There's never enough time to do it right the first time, but there is always enough time to do it over again".
If you don't balance the motor now, you'll almost certainly regret it, and things may be bad enough that you have to tear it down and start over again anyway. So, just do yourself a favor and do it right, while you're at it.
When I have as much money as I do in this project the $200 - $380 isn't a big deal; I guess I just don't have confidence that I will be getting my money's worth out of the deal and I don't want to leave my parts at the other guys shop for 6 weeks if I don't have to.
It looks like the pistons and pins are going to be about the same weight as the stock pistons and pins (probably just a little lighter) and I am using the stock rods and crank. I wish I could find the stock weight for '81 pistons. I saw somebody had posted '76 piston and pin weight and it looks close but I don't know.
After reading more in the archives, it looks like with a stock crank, stock rods, and pistons/pins just slightly lighter weight than stock that I should be fine but my concern then is the weight difference between the rod/piston assemblies with one being 10g lighter and one being 4g heavier. I could always weight match them by removing material from the pistons but don't know if that's a good idea either or where to remove the material from now.
I'm just trying to figure it all out. I want to feel like I'd get what I was paying for if I took it for balancing and I don't want to leave my stuff for 6 weeks.
Vizard says "About 50 grams of overbalance can be used before there is a detectable loss of smoothness [in the engine]". What he is referring to is starting with balanced pistons and rods, checking the weight of the rod little end, measuring the overall weight of a rod and subtracting the little end weight. Then add together the wieght of the piston assembly, little end and twice the weight of the big end including bearings and 2 grams for oil. Then, assuming a crank is balanced to the stock weight of 1870 - 1900 grams and your calculation above is between 1850 and 1900, then the crank doesn't need to be rebalanced. This is where the 50 grams comes from. This is strictly speaking to the calculation above being up to 50 grams lighter than what the stock crank is balanced to.
He goes on to say that "Foregoing balancing does not mean that there will be more destructive internal engine loads present. What it does mean is that whatever forces are generated at one journal may not be fully countered at another. The result is an out-of-balance engine. But the engine is no more likely to fail than if it were perfectly balanced." It would be wrong of me to not point out that he also says "If the budget is available, get the crank balanced." In my case, it's not the budget that's stopping me but I do feel there are roadblocks in my way.
So, I think that if my pistons were all the same weight, and weighed less than the stock pistons and pins, then my situation would fall into what Vizard says doesn't need a crank rebalancing since it is stock and the rods are stock. However, this doesn't answer my question of whether the 10g under and 4g over are going to make a real difference in my application. I feel somewhat confident at this point that I would be fine without a balance job if all my pistons weighed the same but it would definitely be nice to continue to hear other people's views and thoughts on the matter. As a collective group I have always gotten the right advice here on the forum and I appreciate you guys a lot.
BTW ... as pistons go ... your new ones are heavy.
IMHO ... vizard's pretty good ... but he ain't God.
upon hearing that, I am not totally amazed upon reflection....so you need know under what conditions your engine was balanced....
and I would not trust the readings off a typical machine shop....
there IS a shop near me, that is way the hell out in the stix, and I suppose that is when they do the work, there is allways work in progress, i'ts a father son team, they not cheep, and build race engines for all sorts of folks....pros down the list....but with their location at 3am....there ain't no ground vibrations...eh what??
so everyone that criticizes a stock factory balance job, you gotta think about what conditiions they are facing/working with....not as easy cut/dried as one would think....
I knew you guys wouldn't let me do the wrong thing!
