All over the place
Old May 23, 2007 | 10:19 PM
heliflyer1's Avatar
heliflyer1
3rd Gear
Default All over the place
I have a 81 and it wanders all over the place going down the road what am I missing? I replaced the upper and lower ball joints, the tie rods the steering box and steering control valve had the car aligned still all over the road. any help would be apperciated.
Old May 23, 2007 | 10:20 PM
ShinodaVette's Avatar
ShinodaVette
When you replaced the steering box, did you replace the rag joint? That's what I would suspect at this point.
Old May 23, 2007 | 10:28 PM
wiseman79's Avatar
wiseman79
Center link?
Old May 23, 2007 | 10:29 PM
sjmaster's Avatar
sjmaster
My 81 did not wander at all, but did have some play in the steering wheel....and thus slightly "fun" to steer at times. I put on the lift and found the idler had play. Installed a NAPA HD piece and was shocked what an improvement it made...steering is perfect now. This was one of my more pleasurable undertakings of late....unlike the 5 hour cursing match with the motor mounts. Job took about 45 minutes, and only 3 minor curse words uttered.
Old May 23, 2007 | 10:42 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
look at the rear end.....trailing arms, alignment, strut rods etc....
Old May 23, 2007 | 10:53 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'd go here first. When idler arms wear out, they can cause wandering.
Old May 23, 2007 | 10:55 PM
blunblk68's Avatar
blunblk68
Originally Posted by wiseman79
Center link?
I second that!! had the same problem with my chevelle changed it no more wanderin!!
To All over the place
