Frt. Brk. Rotor Rivets
Old May 25, 2007 | 11:36 PM
hpranch's Avatar
hpranch
Default Frt. Brk. Rotor Rivets
I have owned C3's for over 20 years and have never had to replace a front rotor. I am now replacing all 4 on my 82'. The rears were not riveted, and thats easy, but I was surprised to find the front ones riveted. So I need to drill them out to put on the new rotors. Does anyone replace the rivets, or just let the wheel sandwich it on?
What do you think?
Eric
Old May 25, 2007 | 11:44 PM
GDaina's Avatar
GDaina
you sure you haven't mixed up the fronts with the rears?
The wheel will hold the rotor in place...I haven't had any problems with the rivets drilled.
Old May 26, 2007 | 12:14 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
1) search is your friend, those rivets have been discussed to death. Short answer - they were put on for ease of line assembly. If your new rotors have the holes, the hubs can be tapped for a screw. If not, it's not a big deal.
2) George, all four rotors were riveted from the factory.
Old May 26, 2007 | 12:17 AM
GDaina's Avatar
GDaina
thanks...must be getting senile...can't remember the fronts being riveted...
Old May 26, 2007 | 04:38 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There aren't too many C3s that still have the fronts riveted...mine were drilled out and replaced with 5-hole rotors sometime before 1991.
To Frt. Brk. Rotor Rivets
