1980 glove box lock removal
I have seen this written in previous posts but cannot seem to find it.
The glove box lock is loose. I would like to remove the lock cylinder to
enable tightening up the lock. How do you do this? I do have the key
if that is useful in removing the lock cylinder.
Open the glove box -close the latch-put a paper clip in hole on right side and push in tumbler-insert key-remove lock---to put lock back in you must close latch
pay attention to the way it comes out and the way you put it back together because if you put it in backwards it will get stuck in there and next to impossible to get it out without damaging the locking mech.
I have the same lose lock problem, and couldn't figure out how to remove the lock. I thought I was going to have to get medieval on it with a cordless drill.
Mike
This sounds like what I did wrong. I was able to get the lock mechanism out and tighten the loose nut on the housing. I then reinserted the locking mechanism and it got stuck about halfway in. I cannot get it in any further or remove it. Does anyone have any suggestions?
Mike
Mike
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
