Header wrap/glowing headers
Old May 26, 2007 | 09:33 PM
JustinD's Avatar
JustinD
Default Header wrap/glowing headers
I have header wrap on one of my headers but not on the other. (The 50 foot roll is only good for one I guess) I have never noticed this before but after I got done driving it I could see the header glowing down by the collector. Is this just because the wrap is keeping all of the heat in?
Old May 26, 2007 | 09:36 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
That's pretty much it. The wrap is doing it's job keepeing the heat in the tube, but where the insulation ends the extra heat wants out. You're not eliminating heat with wrap, just moving it further downstream. Experiences like your's are why I never installed mine...
Old May 26, 2007 | 09:38 PM
JustinD's Avatar
JustinD
Should I take it off and not wrap the other one, or should I be fine?
Old May 26, 2007 | 09:42 PM
SIXFOOTER's Avatar
SIXFOOTER
I would wrap them both all the way to the mufflers, keep the heat heading out the back and not in the cabin floor
Old May 26, 2007 | 09:44 PM
TheSkunkWorks
If the hot spot is in a place where it may cause damage to something else or create a "hot-foot" situation on exteneded drives I'd probably remove it, but I'm not sure the header itself would be apt to meet a premature end because of it. ??
SIXFOOTER may have a good idea, if you want to buy that much material.
Old May 26, 2007 | 10:02 PM
JustinD's Avatar
JustinD
Ya, I would like to keep it on I think I may just wrap the other one too. I'm not sure about going all the way back that would get spendy plus my current exhaust is all hacked up. If the header fails I guess that is a sign saying I need hooker sidepipes. I just wanted to make sure that is was normal for it to glow in there.
Old May 26, 2007 | 10:15 PM
TheSkunkWorks
I've got an unused 2" x 100' roll of Thermo-Tec if you're interested.
Old May 26, 2007 | 10:20 PM
JustinD's Avatar
JustinD
What color is it?
Old May 26, 2007 | 10:21 PM
TheSkunkWorks
Original "white".
Old May 26, 2007 | 10:22 PM
JustinD's Avatar
JustinD
I'll have to pass, the stuff I have on is black. Thanks for the offer though.
Old May 26, 2007 | 10:23 PM
TheSkunkWorks
Old May 27, 2007 | 06:46 AM
Rotonda's Avatar
Rotonda
If you wrap your headers, it will void the warranty from header manufacturer because of pipe corrosion. Some while ago I used it to wrap my new aluminized exhaust pipes from the manifolds back to the transmission crossmember to try to cool down the interior. After wrapping I painted them with the manufacture's recommended siliconized high heat paint. About 2 years (approx 20,000 miles) later, the wrapped pipes blew out. There wasn't much left under that wrap except rust. I would not consider wrapping anythilg less than a a high nickel (300 series) stainless steel pipe.
Old May 27, 2007 | 07:16 AM
Crunch-o-Matic's Avatar
Crunch-o-Matic
JustinD - the best thing i have found to eliminate heat is to have the headers ceramic coated at Jetthot or the like. I have sent Jetthot used headers and had them do the coating. It makes all the diff in the world and it wont cause the exhaust system to rot out.
Coated headers are a fantastic way to get a ton of bang for your buck.
Cheers,
Crunch
Old May 27, 2007 | 08:55 AM
JustinD's Avatar
JustinD
I'll have to think about jethot in the future. I don't drive in the rain so the only condensation is from the heating and cooling of the headers. Plus I'm not really worried about them they are just summit brand ones. If and when they blow out I will get some hookers and have tyhem jet hot coated most likely. Since I always hear people talking about how good it is.
Old May 27, 2007 | 09:44 AM
hosspowerinc's Avatar
hosspowerinc
Is your engine running a little lean possibly? That would send the exhaust temps soaring as well. If I were you I would just keep them wrapped till they blow and get a set of jethot ones.
Old May 27, 2007 | 10:00 AM
L88Plus's Avatar
L88Plus
I'm with hosspower - sounds like you're either running lean or timing is off. Your headers/exhaust shouldn't glow red with or without header tape. By the way, Summit has ceramic coated headers for just over $200...
Old May 27, 2007 | 10:04 AM
...Roger...'s Avatar
...Roger...
Originally Posted by hosspowerinc
Is your engine running a little lean possibly? .
Your backfire?
Do you notice one header tube that is hotter than the rest?
To Header wrap/glowing headers
Old May 27, 2007 | 11:00 AM
Red 69's Avatar
Red 69
I was experiencing too much interior heat and after vapor lock in traffic ruined my afternoon, I decided to do something. My headers are of the ceramic coated variety, but didn't help as much as I could tell. I wrapped my entire exhaust, headers back with Thermo Tech 2" X 50' rolls; it took five of them. My interior heat is way down and no more vapor lock. Would I do it again, you betcha. At this time, about six months later I don't see any signs of rust, but if it does, so what. My interior is much more comfortable and the composite rear spring is insulated from exhaust heat. I did have to make a skid plate to protect the material on the bottom of the pipes from shredding.
[IMG][/IMG]
Since these photos I have painted them with high heat silicone as suggested by the manufacturer. I was going to be driving in rain, so I thought it was a prudent addition.
Old May 27, 2007 | 11:11 AM
SIXFOOTER's Avatar
SIXFOOTER
Nice
Old May 27, 2007 | 12:17 PM
norvalwilhelm's Avatar
norvalwilhelm
Is it lean? I had this problem, both my headers would glow after a run. I got a LM-1 wide band oxygen sensor and it told me to lean out the motor. I went from 80's to 74 in the primaries and I no longer have problem with glowing headers.
I would say it is too rich if it is glowing.
