Screw Down HEI Cap
Old May 30, 2007 | 11:43 AM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by jackson
Question for you guys that have vette (ie 84-91) with screw-down HEI caps.
Does that dist have both mech & vac advances? ... both preferred for most carbed street motor. If not, perhaps advances could be retrofitted.
Man that's a whole new thing for me. I actually have a kit to add adjustable vac advance to my dizzy but I have no idea how it works or how to adjust it. When I buy the new distributor I will be installing it and will probably need help adjusting it.
Old May 30, 2007 | 11:46 AM
big_G's Avatar
big_G
No vacuum or mechanical advance. All done by the e.c.m. and module. Don't know if it can be modded.
Old May 30, 2007 | 11:56 AM
jackson's Avatar
jackson
That's just what I thought. module is probably 5 or 7 pin ... not the 4 pin found in early HEI.
Old May 30, 2007 | 01:30 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Originally Posted by tigers123
I had one on order from Jegs. Been back ordered for months.Evidently there is a problem with this cap as it also dropped from accel catalog as well. I had heard there is problem with corrected caps crossfiring for some reason. I like the idea of trying to straighten out the cap for making the wires neat, however if cap causes problems don't need that.
This could be the reason why the previous owner sold it....
Old May 30, 2007 | 02:08 PM
jackson's Avatar
jackson
Default xfire
Until the "new" Accel ... The corrected caps have been sold for years... they were/are a modified stock cap ... often marketed under an ill-fated but appropriate name: "crossfire cap" ... those modded caps have a bad reputation for doing just what they're named. The Accel is a new design that's "supposed" to have remedied the old modded caps' problems. Maybe not, I dunno?
here's some history of crossfire cap:
http://www.geocities.com/harleyheart...trodheaven.htm
Old May 30, 2007 | 07:34 PM
JackDidley's Avatar
JackDidley
Just some extra info. The computer controlled distributor will not be a bolt on conversion to use non computer guts. The module screws are not even in the same location. I have a modded one in my street/drag car. Modded the terminal that the module plugs to. Drilled mounting holes in the base. No advance at all. Very simple set up. Locked in at 36*. No springs and weights to go bad no vacuum canister. Works great, but not recomended for a daily driver. I would just sell that cap.
