Looking for an opinion
Old May 28, 2007 | 07:33 AM
hgm's Avatar
hgm
Default Looking for an opinion
I have been collecting parts having machine work done and am getting ready to start building a new 383 for my tired 78. I am using a 99' 2bolt 350, 1 piece rear main seal roller cam block. I have installed ARP main studs. Block has been clearenced for an Eagle cast 383 crank. I am usig chevy 350 rods that have been rebuilt with ARP bolts, Keith Black Flat top pistons. Deck height is at 0. Dart pro I 200 cc alum. heads. Comp will be @ 10.5 to 1. Crane cam is a custom grind with their .539 / .558 lift but ground at 292 duration to maintain resonable vacuum. Any oppion / suggestions of this combination
Old May 28, 2007 | 09:41 AM
Jims79's Avatar
Jims79
I don't think you need anyones help, sounds like you got it all together. The only thing missing is the intake & carb. Whats your plans there?
Old May 28, 2007 | 09:49 AM
hosspowerinc's Avatar
hosspowerinc
Sounds like a good combo to me.
Old May 28, 2007 | 09:58 AM
hgm's Avatar
hgm
Air gap manafold and a holly 780 which I happened to have. I guss I was looking for comments on the selection. or any ideas on what mjght wwork better,
Old May 28, 2007 | 10:03 AM
hosspowerinc
I think that would be a perfect match to you build. Only thing I could suggest would be check your dcr. If your not familiar with that, do a search and there is a lot of info on the forum about it.
To Looking for an opinion
