Reverse lockout cable fix
Old May 28, 2007 | 06:11 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Default Reverse lockout cable fix
Anyone have a slick way to repair the reverse lockout cable that keeps kinking down at the transmission shift linkage lever? I was thinking about silver soldering the cable end to stiffen it????? Anyone have a better idea.....short of just disconnecting it .....
Bullshark
Old May 28, 2007 | 06:16 PM
Duke94's Avatar
Duke94
The cable must be binding on something. Did you try a little WD-40 on it?
Old May 28, 2007 | 06:23 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Yep, I soaked it in PB Blaster. It's not in a bind now, but I think that was the initial problem. Once the cable is bent, It appears to weaken the cable stiffness. I have repeatedly tried to straighten it with no success. Just thought I would ask if there were any tricks out there.
Bullshark
Old May 28, 2007 | 06:30 PM
Durango_Boy's Avatar
Durango_Boy
Bullshark
A little blue pill?
Seriously I couldn't imagine replacing it would be very hard or expensive.
Old May 28, 2007 | 07:16 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I just sold one earlier this year. I think TNBUSA may still have his lockout cable. Send him a PM and check with him. I know he had one too at Corvette Expo earlier this year.
Old Dec 20, 2009 | 03:10 PM
sashabigdeal's Avatar
sashabigdeal
I actually installed a new cable and still have the problem. Maybe it's in the steering column?
To Reverse lockout cable fix
