dc controller
Old May 29, 2007 | 04:57 PM
steve dalla's Avatar
steve dalla
Default dc controller
does anyone have a phone # for him? im ready to order fan combo but would like to speak with them first to see which one is right for me. ld like to run electric pump also, has anyone here done that? comments? I know his product is well liked but have had bad times with internet companies. thanks
Old May 29, 2007 | 06:48 PM
Durango_Boy's Avatar
Durango_Boy
I suggest the Delta DC controller, and for most applications the FK35 is more than enough to a single high powered fan or two mild fans.
Originally Posted by DCC
Our controllers are rated byway of their nomenclature to indicate their current capability, as an example, an FK35 is capable of providing 35A of continuous current, these ratings are given in consideration of reliable operation under real world environmental conditions, so there is no need to under rate the application. In other words, a cooling fan that consumes 35A of continuous current requires the use of an FK35 controller, and although a 60 series controller may be substituted, there is no significant benefit in doing so.
If you're using two high powered fans, then get the FK60.
As far as the water pump...unless you are racing your car on a straight track I would advise against the electric pump. It will not give you the same flow and will be more prone to wearing itself and the alternator.
Also, when installed electric fans it's a good idea to look at your alternator and upgrade if needed.
Old May 29, 2007 | 07:59 PM
steve dalla
phone number?
Old May 29, 2007 | 08:46 PM
Durango_Boy
Originally Posted by steve dalla
phone number?
Don't know. I checked the website and couldn't find one. I ordered online, and all correspondence was via email.
Old May 30, 2007 | 04:46 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My controller came in today.
Old May 30, 2007 | 07:32 AM
Durango_Boy
Mine came last week. I will install it but I won't use it until my electric gos in with the 405.
Old May 30, 2007 | 03:28 PM
steve dalla
how long did it take to get your parts? Im looking at the fan combos one is w-mark8 fan other is taurus fan.will the mark8 fan fit i have stock size radiator? both come w-prewired controller. also (correct me if im wrong) if u have a variable speed controller on the pump will that them make it suitable for limited street-strip action? thanks for all the info!
Old May 30, 2007 | 03:57 PM
blueray72's Avatar
blueray72
How long did it take to get your controller? still waiting for mine.
Old May 30, 2007 | 04:33 PM
Durango_Boy
Mine took a little under three weeks. Keep in mind they are custom made after the order is placed.
Old May 30, 2007 | 04:35 PM
SIXFOOTER's Avatar
SIXFOOTER
I got mine in 2 or 3 weeks, sometimes it takes him a bit longer. He has a real job and a life too. Be patient, it will come
Old May 31, 2007 | 05:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Just shy of four weeks.
Old May 31, 2007 | 04:39 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Took about 4 weeks to get mine.
His number is on one of the pages of his site
I'll try to find it for you
There it is right on the installation page.
To locate an authorized DCC service center, contact DeltaCurrent Control at (408) 379 - 8951
To dc controller
