crate motors?
Old May 30, 2007 | 09:02 AM
kanngaroo jack's Avatar
kanngaroo jack
Default crate motors?
Have a 80 vette. I am thinking of a crate motor . Any idea's of a good motor with out to much hassel of replacing drive line ?
Old May 30, 2007 | 09:41 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
We need a few specifics here. How much hp etc. I put a 350/330 gmpp crate motor in my '80. No real big deal. The motor pulls hard and the car is plenty fun to drive. Go under my profile and look at my homepage. There are some pics of the swap there.
Old May 30, 2007 | 10:59 AM
Crunch-o-Matic's Avatar
Crunch-o-Matic
ZZ4 or stroker would work well. I have the zz4. All depends on what you want.
Old May 30, 2007 | 11:10 AM
Brandywine's Avatar
Brandywine
ZZ4 or ZZ383... no problems with the fit in a 1980.
Old May 30, 2007 | 04:49 PM
Roughrider's Avatar
Roughrider
The ZZ4 is an excellent engine but makes its power primarily at higher rpm's. If you live at those rom's it's great, plus the wow factor of the ZZ4.
A better choice for a strictly street car is the 350 HO 330hp. It makes its power and torque at a lower rpm range that is more amenable for the street. About the only negative thing for all intents and purposes is some weight since the 350 HO has iron heads instead of aluminum.
I had a 350 HO installed in one of my cars (not a Vette) and had Edelbrock Pro-Flo RPM fuel injection added. It's not done yet as the car is still in the body shop, but it promises to be an awesome system for pleasure driving.
Old May 30, 2007 | 07:20 PM
Kalway's Avatar
Kalway
Motown 454! 600hp on pump gas! Rawr!
Ha that thing costs twice as much as I even paid for my vette!
I'd say a ZZ4 is a good bet. I'd say anything with vortec heads, personally. Love those things.
Old May 30, 2007 | 08:04 PM
SILVERSIXX's Avatar
SILVERSIXX
good motor for the money.
Old May 31, 2007 | 12:21 AM
MN80Vette's Avatar
MN80Vette
I have a GM 350 HO in my '80 too. I like the torque in the streetable RPM range. It really came alive when I put full length ceramic coated headers on it.
Old May 31, 2007 | 08:19 AM
kanngaroo jack
Thanks heaps for the reply.I need all the help i can get!
Old May 31, 2007 | 08:23 AM
kanngaroo jack
Man that looks good. If only it had blonde hair !
Old May 31, 2007 | 12:09 PM
68/70Vette's Avatar
68/70Vette
Check out the latest GM Performance Parts Catalog. The number of engine models they're selling now is greater than it was a few years ago. They now are selling a much larger selection of "turn-key" engines;i.e. pull out the old engine and drop in the new and turn the ignition key to start. The ZZ4 is now sold in a turn-key version. Then there's their ZZ383's, 502's, 562 (!). Really eye-popping stuff.
I bought my GMPP Catalog from Summit.
Old May 31, 2007 | 12:52 PM
Machinegun Pete's Avatar
Machinegun Pete
7th Gear
Default Gm 350/330 vacuum
I’m in the process of installing the 350/330 gmpp crate motor in my 79 vette. My friend that is helping me claims that my motor doesn’t have enough vacuum to support the headlights. Is this a fallacy?
I was planning on taking my Vette to dmcorvette to have them check my vacuum lines for leaks. I just want to insure that this engine puts out enough vacuum first.
Old May 31, 2007 | 01:12 PM
piper.gras's Avatar
piper.gras
I would think it should have enough. Just put a 383 stroker in a '78 and it has the Comp Cams 286HR, which doesn't produce much vacuum, and the headlights still work. They certainly don't snap up like they used to with the stock motor, they are pretty slow to open, but they do open. So I think you should be alright, but they may not be as quick to open as they used to be, which I don't really consider to be a problem. Small price to pay for the performance gains.
Old May 31, 2007 | 01:22 PM
68vertible's Avatar
68vertible
Default Sallee/Gilbert Chevrolet
These guys have base GMPP crate engines if you like, plus they add a bit of extra spice and have their own versions if you want something a little wild or different.
http://www.sallee-chevrolet.com/fram...rformance.html
For prices, pick the engine you're interested in and then paste the P/N in the search box at the top.
Old May 31, 2007 | 01:26 PM
69camfrk's Avatar
69camfrk
You won't have a problem I don't think. The motor is only 9:1 and the cam isn't long duration or anything. I need to redo my lines so mine aren't working that well, but that is in large part because of a switch to a Holley carb (lost plenty of vac ports) and the vac fitting on the back of the manifold would not work with it either. I sort of have my vac lines rigged three ways from Sunday, but I plan on having it sorted out before the end of the summer. They were running much more radical cams back in the early days and the headlights came up, so I wouldn't worry!
Old May 31, 2007 | 11:33 PM
MN80Vette's Avatar
MN80Vette
My cousin is a mechanic at the local Chevy dealer and GMPP shop. He says that's a fallacy. I can't personally vouch for vacuum operated headlights with the 350 HO because I have an electric actuators (an early version of the Killer Lights system).
As others have posted, the 350 HO (Deluxe) is one of the best engines for the money, and you can get them serviced anywhere if you don't want to do something yourself.
Old Jun 1, 2007 | 11:04 AM
Al77Vette's Avatar
Al77Vette
I have a 350HO/330 in a 77 and have NO problem with vacuum. It pulls about 15"
Old Jun 1, 2007 | 01:06 PM
Leno's Avatar
Leno
Cruising
Default Crate Motor
I wanted a 350/330 crate myself but the finance's may keep me with the 350/290 ,,, hopefully I will still enjoy it.
Old Jun 1, 2007 | 01:59 PM
Al77Vette's Avatar
Al77Vette
If there is one thing that I learned, it is to buy as much power as you can afford. Adding power later is more expensive unless you can do all of the work. I still like my 350/330, but sometime I wish I had more power to do battle with newer cars.
To crate motors?
