TH 400 Trany Leaks
Old May 31, 2007 | 12:20 AM
PapaJ's Avatar
PapaJ
Default TH 400 Trany Leaks
Hey Guys,
Anyone have a fix for leaking from speedo and copper sending unit on my 77's TH400?
Is it normal?
Thanks,
Joel
Old Jun 3, 2007 | 11:44 PM
PapaJ's Avatar
PapaJ
ttt
Old Jun 4, 2007 | 12:02 AM
chris73cpe's Avatar
chris73cpe
Easy fix is change the driven gear seal, it's pretty cheap and your dealer should stock them or can get them quick enough. What's more likely is the gear has worn the housing slightly eccentric so a new seal won't last long. You can also order a new housing and gear for I want to say under $30. That did the trick on mine. Mine's a 73, but still a TH400, so I'd think it'd be similar.
To TH 400 Trany Leaks
