Coil Mount
Old May 31, 2007 | 06:29 PM
JustinD's Avatar
JustinD
Default Coil Mount
Where are you guys mounting your coils? I need to get mine in but can't find a good spot that I like for it.
Old May 31, 2007 | 06:31 PM
...Roger...'s Avatar
...Roger...
Hei ?
Old May 31, 2007 | 06:48 PM
JustinD's Avatar
JustinD
MSD Blaster 2
Old May 31, 2007 | 07:16 PM
JustinD's Avatar
JustinD
Also, where would be a good ground?
Old May 31, 2007 | 09:03 PM
Little Mouse's Avatar
Little Mouse
Huuum you got rid of the HEI, your intake should have the two
holes at the back to use the original earlier coil bracket.
Old May 31, 2007 | 09:16 PM
JustinD's Avatar
JustinD
I mounted it to the fire wall. Well, now the car is more like it should be. I romped it from a complete stop and the car was instantly sideways. My initial timing is 21*. as for my total, does 47* at 2500 sound like to much? It runs like a bat outta hell.
Old May 31, 2007 | 09:43 PM
JustinD's Avatar
JustinD
http://24.118.233.41/msd.html
Old May 31, 2007 | 11:13 PM
Little Mouse
36 to 38 total.
Old May 31, 2007 | 11:16 PM
JustinD's Avatar
JustinD
Even with my large cam I don't want any more than that? I guess it shouldn't be to hard all I have to do is look at a chart and adjust the switch inside accordingly.
Old May 31, 2007 | 11:20 PM
Oldguard 7's Avatar
Oldguard 7
Is the msd blaster 2 distributor a points dizzy?
Old May 31, 2007 | 11:26 PM
JustinD's Avatar
JustinD
No, the Blaster is the coil, the distributor is a MSD E-curve. The advance is all computer operated.
Old Jun 1, 2007 | 07:59 AM
pws69's Avatar
pws69
Depends on what you call "total". If the vacuum is disconnected, it's too much - if connected, you're golden!
Old Jun 1, 2007 | 08:05 AM
JustinD's Avatar
JustinD
Ya, no vac advance. I don't want to run it. I guess I will have to dial it back.
To Coil Mount
