QJet Idle Problems
79 qjet.
No choke or choke linkage.
Problem
Idle is either 2000 RPM usually cold or just at temp or it drops to the point of stalling.
runs great at cruise and at WOT.
The stalling usualy happens at operating temp.
runs great at cruise and WOT.
Ideas?
I believe my timing is set correctly.
I had a similar problem and it turned out that someone in the past had removed the choke pull off and the fast idle cam and when they put it back on they did not attach the cam at the bottom of the choke linkage to the cam off the fast idle.
The result was the car would not hold idle until it was real warm. Prior to warming up it would only run if you held idle at 1500 RPM. As soon as you backed off the gas it stalled. Choke butterfly was not movable even by hand.
I pulled the fast Idle cam and threaded it thru the choke and it worked great. The choke needs to be closed at startup and then slowly open as it warms up. If it doesn't it will be hard to start and even harder to hold idle.
Be sure to plug the vacuum port to the coil chamber!
I had trouble with it occasionally sticking.
The only thing I really notice is if im not up to temp and the secondary try to kick in it bogs. (no choke = no secondary lock out)
btw, I did know to plug the coil port.
my vette is up to temp in a few minutes anyway.
