Rear Adjustable camber strut thread question
Old Jun 3, 2007 | 03:59 AM
Ybnormal's Avatar
Ybnormal
Default Rear Adjustable camber strut thread question
Sever years ago I bought the adjustable rear camber strut rods but can't remember who I bought them from. One end has a grove around it to indicate either left or right threads but can't remember which. Does anyone have a set of these adjustable strut rods (originally came gold in color) with a grove around one end, that remebers if the grove end is left or right hand threads. The reason I ask is I used a lot of lock-tit on the nuts once the rear end was alligned and I'm having difficulity breaking the nuts loose, don't want to strip them.
Thanks,
YBnormal...drive a vette
Old Jun 3, 2007 | 09:50 AM
dfolse62's Avatar
dfolse62
I just looked at a new set that came with my car. Sorry but they are marked L and R. Can you visually inspect the exposed thread to tell which they are? Also, I need to install mine. What is the process? Is it to put car on jack stands then put pressure on the spring end to bring to level and then just change them, or is it a lot more complicated?
Old Jun 3, 2007 | 10:21 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
if you didn't use antiseze or grease and they have been on the car for a few years they will be very hard if not impossible to break loose. Ask me how i know.
Old Jun 3, 2007 | 01:54 PM
C3 Stroker's Avatar
C3 Stroker
Thanks,
I have them, also, and the groove end indicates left hand threads. I would not use loc-tite, but some people have had them loosen up. I would just use a little anti-sieze and tighten them up good. (After a couple months you can always re-check them).
Old Jun 3, 2007 | 02:08 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I almost lost control my vette when the passenger side loosen and the wheel was severly inclined outwards! I dont know what caused that but when I checked it both sides were on their last few threads! that was scary!! I dont know what caused that rapid turn of threads but I strongly advice anyone who got the adjustable ones to tight them very well.
Old Jun 3, 2007 | 02:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I have a set of VB&P's adjustable strut rods - I found some metric wavelock washers to install between the lock nuts and the rods. Hopefully that will reduce any tendency to loosen.
Old Jun 3, 2007 | 03:55 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Sounds like a very good idea. Keep us posted on how it works out as I might do the same with mine.
I still have my adjustable strut rods out in the garage. Been there for a couple of years now. I need to get off my butt and get them in there. Maybe this winter when the LS goes in I will put the strut rods in there too.
To Rear Adjustable camber strut thread question
