I'm considering dropping in a crate stroker engine in my '80, but I'm concerned that the differential might end up being the weak link in the chain. Were these late C3 differentials as strong as those behind big block cars?
TIA for any helpful replies
I ran 400 or so horse through my stock diff for a while. It held up fine, the problem is with a big cam that doesn't pull until higher rpms so you don't have squat for acceleration.
I bought a 'new' service replacement unit off eBay and promptly had a shop blueprint it along with adding 3.54 Dana/Spicer gears. They set it up with much closer tolerances than GM. I'd say it is good behind a 400hp engine. My engine produces approx 300hp at the flywheel.
My 1981 aluminum diff took a beating on the back of my 450hp 406 . I drag raced occasionally and did drive it hard on the street . Never a problem. But you never know...it could have been a grenade just waiting to explode with the right conditions. I never had good traction on the street or the track so that might be why. I had 2.1 sec 60' times with a 12.9 sec 1/4 so no grip there.
The good news is you can get an earlier iron diff and replace the aluminum one with it, same bolt pattern, it'd be an upgrade.
Not necessarily. You could simply be replacing the lighter aluminum piece with an anchor. The 80 stock rearend will hold up to a lot of abuse, especially for a street driven vette.
