Quadrajet issues (7042203)
Old Jun 4, 2007 | 04:33 PM
csams's Avatar
csams
Default Quadrajet issues (7042203)
I sent this question to Lars (the MAN) ....but thought the general group may benefit from the discussion as well.....
I have a 7042203 Qjet that is not working properly...
I pulled off the airhorn last night and noticed the following issues:
-incorrect primary rods (coded 44B instead of 45)
-incorrect secondary rods (coded DP instead of DA)
-passenger side 'secondary accelerating well tube' was laying loose in the secondary accelerating well - check out the picture
-I can read a 74 (correct) on one of the main jets but the other one is not marked
My questions are 1) where can I get correct rods? 2) how should I reattach the well tube to the air horn (epoxy, pound in, other?) 3) where can I get correct main jets.
Any other suggestions? Thanks....Chris
Old Jun 4, 2007 | 04:52 PM
Roughrider's Avatar
Roughrider
Try Edelbrock for the parts. They made a version of the Q-jet and should still support them parts-wise.
Old Jun 4, 2007 | 04:57 PM
S489's Avatar
S489
2) clean, reinstall using a drop of loctite
Old Jun 4, 2007 | 06:17 PM
BigBlockk's Avatar
BigBlockk
You can get parts here.
http://www.carburetion.com/quadrajet.asp
As far as the secondary pickup tube, you should freeze and tap it back in to a hight of 1". Freezing it should make it easier to install.
BigBlockk
Later.....
Old Jun 4, 2007 | 10:41 PM
Disco_Mike's Avatar
Disco_Mike
I ordered the edelbrock jet and rods thru autozone.
is you search their web site you can get the part number there.
I am missing one of the tubes in my air horn. anyone know where I can purchase one? other than buying a scrap qjet for parts.
Old Jun 5, 2007 | 12:20 AM
csams's Avatar
csams
Default Good info....
I was able to locate the '45' primary rod (edelbrock part #1946) and the '74' jet (edelbrock part #1974)....(thanks Lars!).
Also...thx to all for the info on re-installing the secondary well tube.
Now all I need are the secondary rods.... anyone have a couple 'DA' stamped secondary metering rods laying around??
If so, pls send me a message. Thanks....Chris
To Quadrajet issues (7042203)
