need help identifying a part please
Old Jun 4, 2007 | 06:42 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default need help identifying a part please
I need assistance with a part name, number and a vendor who carries this item.
I am looking for a rubber L-shaped boot with two holes that goes between the vacuum lines and the two-tube pull-down manual override switches under the dash. I have the pull down switches. I have the vacuum lines. I just need the L-shaped rubber connecting boot that connects them.
If anyone has a couple of spares, let me know. Or an item number and a supplier will work.
Thanks in advance
Dan
Old Jun 4, 2007 | 08:27 PM
71rdster's Avatar
71rdster
Try Dr. Rebuild. I don't have a part number or description.
Old Jun 4, 2007 | 08:28 PM
Duke94's Avatar
Duke94
I think this is the part. I've never seen them in any of the catalogs, used is proably your only choice. I looked in Doc's catalog and could not find a listing
Old Jun 4, 2007 | 08:32 PM
corvetteload's Avatar
corvetteload
Dr rebuild doesn't have them, according to the *** Man they are part of the vacuum harness. I would get a Hemmings Motor News and call every used Vette parts place in there, you will surely get some!!!!!!!
Old Jun 4, 2007 | 09:11 PM
MikeMc71's Avatar
MikeMc71
I found to cure all the leaks in my '71, I had to remove these and put the lines straight onto the valves. The arizona heat is tough on these!!
Old Jun 5, 2007 | 10:39 AM
brdd's Avatar
brdd
Yep that's the parts. I will try the recyclers if no one here has any. I can't believe I lost one. I'm usually careful about that sort of thing. I know none of you fellows have lost anything, have you?
Old Jun 6, 2007 | 09:54 PM
jjarrett's Avatar
jjarrett
Default vacuam override
hey duke 94! in your pic what is that setup ,i know about the valve with the pull off-on but what is the rest of the switch and vacuam thing. thanks=john
Old Jun 6, 2007 | 09:57 PM
Duke94's Avatar
Duke94
On cars with the wiper door, the switch turns off the wipers so you can change the blades when the wiper are out of their house. There are 2 manual vacuum valves, one for headlights and one for wiper door.
To need help identifying a part please
