Advice needed on cam advancing
Old Jun 4, 2007 | 08:48 PM
tomcat65's Avatar
tomcat65
Default Advice needed on cam advancing
I got a -70 300hp 350 engine,
stock 300hp cam,, with dart eagle iron 64cc heads just slight surfaced machined, comp roller 1,52 rockers, //Wanted to ad it is a 10,25 1comp engine
I wonder will 2´advancing cam build too much static compression for this combo ? or should I go stock or even retard marking on the roller chain?
any help apreciated
Old Jun 5, 2007 | 06:30 AM
stingr69's Avatar
stingr69
With the stock 350/300 hp "929" cam you would not want to advance it. You might want to retard it a few degrees if you needed a couple hundred more top end RPMs but in all honesty if that sounds good to you, you probably have the wrong cam in there in the first place.
-Mark.
Old Jun 5, 2007 | 07:04 AM
tomcat65's Avatar
tomcat65
Thanks for your reply,
hmm,, it is still the stock cam that in there and I have just taken the timing cover off to install a new chain and while I am at it maybe I should go with the L82 cam that I have on my shelf and advance that one to get more torque at low revs while I have it apart,,
any thoughts ??
the thing is I have 3,08 rear gears and I drive a fair amount around town, so i kind of want a good low/ mid torque engine too,
Old Jun 5, 2007 | 07:31 AM
Matt Gruber's Avatar
Matt Gruber
1st i'd do a cranking compression test
Old Jun 5, 2007 | 08:45 AM
stingr69's Avatar
stingr69
any thoughts ??
The L-82 "962" cam would be a good choice to get more HP but that cam is a little bit lazy off idle. I run one in my Vette and like it but the "929" has more torque off idle.
Advancing the L-82 cam might be good if you want more grunt at lower RPM's.
-Mark.
Old Jun 5, 2007 | 05:00 PM
Scott Marzahl's Avatar
Scott Marzahl
I believe the L-82's Intake Center Line is at 114 degrees, if so, you could easily advance it 6 degrees to a 108 ICL for more torque at the loss of some top end.
Old Jun 5, 2007 | 05:19 PM
tomcat65's Avatar
tomcat65
Yes the L82 ICL is 114´ and my Cloyes roller drive has a 2 degree built in advance option
so thats what I would do I guess,
the only thing what I am worried about is if this cam also builds too much compression, since I heard this cam was for a lower compression engine ?
I mean i do have flat top pistons and 64cc heads that is slightly surface machined,, like 10,25 give or take ?
but I think I recall some people using this cam and even advanced on higher compression engines !?
anyone has experience with this set up ?
Old Jun 5, 2007 | 05:38 PM
Scott Marzahl
The L-82 cam will definately like 10-10.25:1 compression if you only plan on bumping it ahead by 2 degrees. This is because it has a relatively late closing inlet valve which results in a lower DCR.
Old Jun 5, 2007 | 08:47 PM
stingr69's Avatar
stingr69
I would agree with Scott. You can advance the "962" cam running at 10.25 CR
I would not try advancing the "929" cam at 10.25 CR. I have not tried before but I would bet that it would ping quite a bit.
-Mark.
Old Jun 5, 2007 | 09:17 PM
tomcat65's Avatar
tomcat65
Thanks guys !!!
Old Jun 5, 2007 | 09:36 PM
Scott Marzahl
The max compression for a '929 would be 9.75 with very careful timing and you want to retard it 4 degrees for an extra 500 RPMs up top.
To Advice needed on cam advancing
