Power Brakes
Old Jun 5, 2007 | 08:22 AM
Cherokee64's Avatar
Cherokee64
Cruising
Default Power Brakes
I have a 73 with manual brakes, what do I need to change besides the master cylinder and booster to ease the pedal pressure.
Thanks for the help
Old Jun 5, 2007 | 09:28 AM
70 LS1's Avatar
70 LS1
For a stock power conversion you will need master, booster, new lines from master to proportioning valve and the bracket on the pedal for the brake lights.
For a hydraulic assist, you need to have power steering and get a hydroboost kit.
For a better manual setup, swap out for a Wilwood 7/8" master cylinder. (Personally, I prefer the solid feel of a properly adjusted manual setup.)
Old Jun 5, 2007 | 02:17 PM
Cherokee64's Avatar
Cherokee64
Cruising
Thanks for the info. I do have power steering and your comments concerning the solid feel have me thinking that I should go through the whole system. I forgot to mention i just bought the car, so new parts could make a big difference.
Thanks again
Wayne
Old Jun 5, 2007 | 02:49 PM
70 LS1's Avatar
70 LS1
If you have a high pedal pressure without the pedal sinking to the floor as you hold the brakes, then most likely the system is tight without leaks.
To Power Brakes
