mechanical fuel pump
For an easier time rotate the motor a quarter turn by hand and try again. Repeat until it's a little easier but you will have to work it a bit.
You can either put a bolt through the front of the block and finger tighten against the rod to hold it, or use a hacksaw blade (turned flat) to hold the rod as you place the pump arm against it. Oil will run down the rod trough when the engine is running which is why it leaks from the front of the block if the bolt hole is left open. If you used the bolt method to hold the rod, take the bolt out and replace with a shorter one once the pump is bolted on.
Grease the lever arm mechanism. I don't think there is enough oil pressure to flush any grease, I haven't seen any in the oil after any oil change since.
Funny, I thought all '82 Vettes had TBI and therefore an electric fuel pump in the tank. Unless an earlier motor is fitted and in that case, the long bolt/short bolt tip is a good one. Also, turning the engine until the pushrod is on the "backside" of the pump cam is good advice.
Regards from Down Under
aussiejohn
Its easy. Turn the engine over so you can get the piston up as high as possible. Try the piston...see how far up it goes. Try the pump so you know how to manuover it with out the piston. Then put some grease on the side of the piston and push it up. Immedialtely after position the piston position the pump. Put the bolts in and start tightening. There should be a bit of resitance and the bolts will take up the gap as you tighten. Its spring loaded after all. There is no play between the piston rod and pump lever but silght compression when the piston is in the up position...much more when its not.
Jim
http://forums.corvetteforum.com/show...fuel+pump+tool
I've got a '74 with a '87 Goodwrench Crate Engine in it.
I've had a good look for this bolt (yes I know where is supposed to be within a few inches).
There are a couple of threaded holes up the front there, but they are all blind.
Is this a casting issue - or am I looking in the wrong place
(I'm looking on the front of the block in line with the push-rod)
Cheers,
Photo might help.....
Jeremy.
Cheers,
Jeremy.
My work browser does allow me to see Photobucket stuff.
Any chance of PMing me the piccy or posting it direct to a reply.
Sorry to be a PITA.
J.
Jim
I'm trying to replace my pump today and need to know how far up will the piston go. I have it about halt the length of the piston, is this far enough to get the pump in place?
