More wiper door ?
Old Oct 24, 2001 | 11:48 PM
je68's Avatar
je68
Default More wiper door ?
I am installing Wiper door that someone removed for a L-88 long hood. I have most of the parts and trying to install to check fitt before paint. My ? is does the vac canster adjustment help with lineing up the hood with fenders. Thanks
Old Oct 24, 2001 | 11:51 PM
rainman69's Avatar
rainman69
Default Re: More wiper door ? (je68)
Mine just lined up by tightening the bolts "just tight enough" that they won't come out, yet everything pivots freely. Does that help?
Old Oct 25, 2001 | 12:00 AM
je68's Avatar
je68
Default Re: More wiper door ? (rainman69)
Wich bolts are you talking about?
Old Oct 25, 2001 | 01:48 AM
rainman69's Avatar
rainman69
The four that attach the "hinge" to the actual door. They are the little ones with the nylon washers that screw into the door.
I had the door set in the full up position when I did it.
Old Oct 25, 2001 | 06:49 AM
Larry B.'s Avatar
Larry B.
There are some nylon shoulder bushing that you need so the door will move freely and the bolts will be tight.
Old Oct 25, 2001 | 07:26 AM
Steve Straus's Avatar
Steve Straus
je: those are some sweet valve covers you have on your engine. Where can I get a set like that and do they come in Yellow?
Old Oct 25, 2001 | 08:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
je68 -- If I understand your question correctly, the answer is "No." The vac cannister does not assist with wiper door/hood/fender panel alignment. The wiper door hinge hardware has an adjustment point on each side which is used to set the alignment with the fender tops. There is no alignment with the hood since the wiper panel does not butt up against the hood. The cowl vent panel can be shimmed toward the hood or away from it to close/open the gap by shimming at the points where the brackets attach. My '68 Assembly Manual has good diagrams and instructions for aligning the wiper door and setting up the entire assembly. Get the AIM and look over the diagrams.
To More wiper door ?
