STS Baffles installation?
Old Jun 7, 2007 | 06:02 PM
69vettester's Avatar
69vettester
Default STS Baffles installation?
Does the plugged Pipe face toward the exhaust exit or the engine. Or does it matter, anyone know?
Cheers..
Old Jun 7, 2007 | 06:10 PM
68 NJConv 454's Avatar
68 NJConv 454
Good question.
I also have the STS baffles uninstalled.
How are you mounting these in the 4 inch tubes?
I would like to weld a tab inside the tube but don't want to ruin the ceramic coating JetHot covered the pipes in.
Old Jun 7, 2007 | 06:23 PM
Duke94's Avatar
Duke94
Cheers..
This came up in a post just yesterday. The closed end faces the engine.
Old Jun 7, 2007 | 07:37 PM
Z-man's Avatar
Z-man
Old Jun 7, 2007 | 10:26 PM
dmaaero's Avatar
dmaaero
Originally Posted by 68 NJConv 454
Good question.
The tab is allready welded to the baffle, all you need to do is drill a couple holes in the tube to put the bolts in. I put mine on the lower inside of the tube outa sight. Rember measure 3 times drill once!
Old Jun 7, 2007 | 11:38 PM
rosslato's Avatar
rosslato
same exact method for me
Old Jun 7, 2007 | 11:48 PM
Racer11's Avatar
Racer11
That is correct that the capped end goes toward's the engine.
When drilling the holes in the pipe it is difficult to get the holes to align up perfect with the baffle tabs.
Before you do anything to install the baffles,,,,,run a tap thru the threads on the baffle tab and clean out the threads. Mine were warped a little and the bolts bound up in the tab and I had to break the bolt to get it back out. The manufacture is to run a tap thru them but mine got missed and I had to send the baffles back and get another set of baffles.
Old Jun 8, 2007 | 02:19 AM
68 NJConv 454
Thanks for the tip
Old Jun 8, 2007 | 08:38 AM
69vettester
Isnt it symetrical?
I installed Mine with the Cap not drilled and at the exhaust exit end , But it fit and sounds fine. Is it Not flowing now or what?
Old Jun 8, 2007 | 09:48 AM
66427-450's Avatar
66427-450
Isnt it symetrical?
i thought the intent was to install them with the cap in the rear? so you could remove/replace the cap as needed for flow/sound control.
Old Jun 8, 2007 | 11:35 AM
68 NJConv 454
I would think it would be harder to get at the cap at the rear/turndown part of the sidepipes then if you put the cap where the header and sidepipe meet which puts the cap facing the engine. Just take the sidepipe out of the header and adjust the cap.
Also would think that if the cap was facing the rear of the car any exhaust moisture could collect inside the tube as the exaust flows into it and hits a head end. Possibly causing the baffles to rust quicker. With the cap facing the engine side the exaust is never really forced into the dead end tube of the baffle so any moisture should flow right out of the sidepipe.
Just a thought.
Old Jun 8, 2007 | 11:46 AM
Z-man's Avatar
Z-man
Just a thought.
Yep - the cap at the front is only a couple of inches into the pipe. You could just work on it while it is in the side pipe. In the back, it's about a foot or so into the pipe. You'd have to remove it from the side pipe. From a performance standpoint, it probably doesn't matter at all.
If you wanted to prevent flow pushing stuff into the center pipe, you could just glue or solder a cap on the front end too (with a small hole). I think he said that the caps were the same caps used as freeze plugs in engines.
Old Jun 8, 2007 | 06:41 PM
Racer11's Avatar
Racer11
Isnt it symetrical?
With the cap at the exaust end,,the flow will have restriction entering the tube and botteling up with no outlet less HP and it will capture moisture ,,,,with the cap on the engine side (inlet) the flow will go around the center tube with less restriction.
If you want more flow just drill a hole in the cap,,,you will get more noise also,,,start with 1/2 inch hole,,,,
You can tune these pipes to your specific engine needs. The cap restricts about 25% flow.
The above info was from the gentleman who designed the pipes.
BTW refrain from just starting up the engine and building up moisture in the pipes and not running the car long enuf to burn the water out,,,extending the life of the baffles.
I noticed from my car that when the engine starts up I get a lot of water drip from the pipes until the pipes heat up to operating temp.
The only thing I dont like about the baffles is the 2 holes that need to be drilled,,,,in time the holes will rust out.
I switched from Max flows to the STS baffles,,,best move
To STS Baffles installation?
