Oil on spark plug threads ??
Old Jun 8, 2007 | 08:02 AM
7t6vette's Avatar
7t6vette
Default Oil on spark plug threads ??
I put a 383 stroker (built by ARracing) in my 76 vette about two years ago. It has always used oil but I could never figure out why. Last year I noticed pieces of plastic inside the valve covers and found out it was the valve seals . Took the heads to a repair shop and they had to be rebuilt. I was told the valve seals were being crushed due to the heads not being milled properly? $300 to get that fixed. The valve seals are ok still but it still uses oil. Nothing on the spark plugs just a few plugs have a light coat on the threads. I was also told by ARrcaing the engine would be bored 30 over but have since founf out it is 60 over. The car runs good, plenty of power but smokes lightly (blue). Any thoguhts ?? I don't recommend ARracing.
Old Jun 8, 2007 | 08:15 AM
pws69's Avatar
pws69
Rings are suspect....
- didn't seat right
- one or more cracked
- not installed properly (you said "It has always used oil")
Old Jun 8, 2007 | 10:43 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree that it sounds like a ring problem. I would do a leak down test and a compression test to make that determination. Good luck.
To Oil on spark plug threads ??
