dart block sbc
Old Jun 9, 2007 | 12:26 PM
hkc3's Avatar
hkc3
Default dart block sbc
When i was ready to install heads i noticed the gaskets had tiny holes for cooling water and the block had much bigger holes ,should i enlarge the holes in the gasket to match the block.
Old Jun 9, 2007 | 05:40 PM
Belgian1979vette's Avatar
Belgian1979vette
Don't know exactly why anymore but the answer is no, you should leave them as they are.
Old Jun 9, 2007 | 06:46 PM
evalu8r's Avatar
evalu8r
I believe they are called steam holes for the 400 blocks and heads. Leave them as they are.
Old Jun 9, 2007 | 08:34 PM
hkc3's Avatar
hkc3
The dart block doesnt have the steam holes, I mean the large water ports in the rest of the block,Dart advertises better cooling with revised water jackets so why would you restrict it,unless to keep water in the head longer for better cooling,I dont know for sure. The high volume water pumps pump more water for extra cooling,dont you want the water through the motor faster then in the radiator slower.
Old Jun 9, 2007 | 09:37 PM
AKRAY4PLAY's Avatar
AKRAY4PLAY
the little holes are for restriction on purpose. the water pump fills the block from front to rear and then it turns up at the rear of the motor and flows to the front. if you punch out the holes in the gasket, you will decrease the flow to the rear of the block. it's all about the path of least resistence. by revised water jackets, they mean it flows better from the front to the back of the block, not from the block to the heads.
Old Jun 9, 2007 | 09:53 PM
gkull's Avatar
gkull
I have a Motown block and I enlarged the gasket holes to match up. The problem is the head gaskets are made for Chevy stock blocks, not our aftermarket block.
The race shop pointed this out to me when I has not altered them the first build.
It has to be done to get correct water flow. If in doubt call Dart!
Old Jun 9, 2007 | 09:54 PM
hkc3's Avatar
hkc3
Thanx,.Theres a lot I dont know but Im learning as I go,this forum is great I have learned a lot from It .
Old Jun 10, 2007 | 07:37 PM
hkc3's Avatar
hkc3
Weekend -I cant get ahold of anyone, I went ahead and installed as bought,Ill get ahold of dart tomorrow. Hope I dont have to take heads off.One of the many things you run into as a beginner.
Old Jun 24, 2007 | 10:09 PM
hkc3's Avatar
hkc3
called dart gaskets go on as made.
To dart block sbc
