Edelbrock BB fitment help
Old Jun 10, 2007 | 09:21 AM
sxr6's Avatar
sxr6
Default Edelbrock BB fitment help
Anybody know if an old C-427X Edelbrock aluminum intake will fit under the regular BB hood??
Is it a decent intake? I think I'll buy it anyway just to lighten up the nose seeing as all I have is a non original cast achor intake IF it will fit ?
Old Jun 10, 2007 | 09:57 AM
66427-450's Avatar
66427-450
Is it a decent intake.....
I have a little bit of experience with that intake, 427X....... (see pic below, I have 6 here at the moment)
It's virtually the same height as the GM 069/163 intake.... fits fine on a C2, but on a C3 it would take the L-88 hood setup.
It came in "427" and "427X" the X is the open plenum version..... so expect reduced low end power, and more ~4000-4500 and above (on a std CID BB).
The casting has significantly more runner volume than the GM piece, I've been playing with them (427X) on the flow bench in an attempt to come up with a high flow period-correct looking intake for a my 66 (496 on the way in), so far the intake looks great, a little porting, a little welding, it'll be matted with a set of CNC'd 325 AFRs and a Holley 1000HP. Just what the Dr. ordered........
So....... 1) on a C3 you'd need a L-88 hood, and 2) it's a high RPM intake on a 427/454 (and it kills some low end power, thank god, lol).
Old Jun 10, 2007 | 10:02 AM
66427-450's Avatar
66427-450
this is what they look like if someones interested.........
Old Jun 10, 2007 | 10:14 AM
shafrs3's Avatar
shafrs3
Based on that pic I doubt it would fit.
Old Jun 10, 2007 | 10:48 AM
66427-450's Avatar
66427-450
right, that's why GM designed the C3 low profile BB intakes
here, this pic should help.........
PS: I just remembered, the carb pad is "ranked forward" a bit more than the GM high rise BB intake..... as i recall the average C-427, front and rear measurements, are ~ the same as that of the GM. if someone is really interested, I could measure both, i have a some L-88/ZL-1 & L-72 intakes here as well (but no C3's at the moment, sorry)
Old Jun 10, 2007 | 01:52 PM
sxr6's Avatar
sxr6
Dammm....I figured a piece of aluminum plate & little welding could fix the open plenium but the room under the hood i can't fix
Old Jun 10, 2007 | 07:20 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If it's no trouble, I'd be interested in knowing the carb pad height(s) of the L88/ZL1 piece, so I could compare to the C-454. Thanks!
Old Jun 10, 2007 | 08:59 PM
66427-450's Avatar
66427-450
I don't have a C-454 handy (that's the same basic intake adapted to the Holley Dominator base........ BTW: the C-396 is the oval port version)
That said, I measured a GM intake, and an old Edelbrock C-427X, basically, the same height, the GM was 27 thousands higher (Ave of front and rear measurements)....... probably within manufacturing tolerances (i.e. looks like Edelbrock used the same height limitations as GM)
I placed a straight edge on the carb surface and measured the distance from the front and rear manifold seal/gasket surfaces to the straight edge
GM front = 4.188 rear = 5.625
C427X front = 4.380 rear = 5.381
(looks like GM had more rake, i remembered one did, lol)
I had tried a new Edelbrock RPM a few years ago, it was a bit (~3/8"?) higher than the L-72/L-88, if I remember correctly, don't quote me re that
Old Jun 11, 2007 | 12:27 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The C-427's and C-454's are neat. I've run them on several deals and had good luck with them. I recently saw a back to back test on a 650+ HP 496 pump gas motor. They ran it with a C-454 and a Dominator against an RPM Air Gap with a 2" spacer to mate the Dominator to it. Virtually identical HP/TQ and curves. I wonder how the C-454 would have liked the 2" spacer?
That being said, they also changed to a more aggressive cam and a Vic Jr intake and were up 30 hp. But it wasn't a pure test, so no telling what helped the most?
I have a C-454 that I'm going to play with again one of these days.
JIM
Old Jun 11, 2007 | 01:12 PM
TheSkunkWorks
The reason I asked is that I've decided to dig out my old C-454 to put on the solid roller 496 I'm building up, and plan to fab a proper air box to mate that and a BG 1095 VS to my L88 style hood. The info helps. Thanks, 66427-450!
To Edelbrock BB fitment help
