Frame Dimensions
Old Jun 10, 2007 | 05:52 PM
MarkZ's Avatar
MarkZ
Default Frame Dimensions
My 73 Coupe was on axel stands behind #1 mount when the tree fell on the nose - I suspect the frame has been adjusted slightly!
Does anyone have drawings of the frame body mount to front suspension mount dimensions.
Old Jun 10, 2007 | 06:49 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
http://www.corvettefaq.com/c3/C3FrameDim.jpg
Does that help?
Old Jun 11, 2007 | 10:27 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I don't think those specs are correct for a 73. They ar different from what I have on file.
Old Jun 11, 2007 | 12:10 PM
MarkZ's Avatar
MarkZ
Should Help thanks
If I see correctly the front of the frame, where it is channel shaped .. where the 'bumper' mounts look parallel to the main frame? - ie if I have those level when I get the frame level I'm good . I will also check for twist - ie level the back across the frame I should be level in the front accross the frame.
will check this weekend
Thanks for the help
Old Jun 11, 2007 | 12:14 PM
MarkZ's Avatar
MarkZ
How different are they? If I just work with the leveling of the front with the frame I should be ok?
Thanks for all the help
Old Jun 11, 2007 | 01:03 PM
Van Steel's Avatar
Van Steel
if you have a fax I can fax you the sheet.
Old Jun 11, 2007 | 02:43 PM
cmerrick's Avatar
cmerrick
If you have access to a frame shop, it might be worth it to have them jig it and do the measurments. Wasn't that expensive when I had mine checked for true.
Old Jun 11, 2007 | 03:05 PM
MarkZ's Avatar
MarkZ
The problem is that it is a rare car here (South Africa) and no-one here knows the cars and so won't look at them ! . I was told that the only way I'd get it jigged here was if I did a body off (again) - So I just want to do a basic check before I go ahead with the front clip replacement. I'll make a plan to measure it myself - I do have access to good measuring equipment.
To Frame Dimensions
