Windshield Trim and Door Panel Bezel Paint?
Old Oct 25, 2001 | 05:54 PM
Edzred72's Avatar
Edzred72
Default Windshield Trim and Door Panel Bezel Paint?
OK, I've tried two types of paint on my door panel bezel's in my 77, and neither seems to stick :U I've cleaned up all the old cracked paint, roughed up the metal a bit and tried Krylon semi flat black enamal, let it cure... no good. Then I tried a black satin rust inhibitor enamal.. still flakes off and leaves marks to the touch. :smash: What am I doing wrong :confused: Do I use a clear coat over the paint to harden the finish? I want to do the windshield trim in black also.. but first I need to find the right paint that will stick. Is there one paint for both applications, if so please advise a dope! :crazy: :mad :mad THANKS.... :cheers:
Old Oct 25, 2001 | 09:14 PM
71roadster's Avatar
71roadster
Default Re: Windshield Trim and Door Panel Bezel Paint? (Ed T)
I just used some self priming epoxy paint on mine. Looks perfect and the epoxy paint really holds up, and the "self priming" action seems to make a BIG difference. Got it in a spray can at an auto parts store. If removing old paint is necessary, I always use jasco, at least on metal parts.
Chris
Old Oct 25, 2001 | 09:49 PM
Juliet's Avatar
Juliet
Default Re: Windshield Trim and Door Panel Bezel Paint? (Silvr77)
I cleaned the old stuff off with lacqeur thinner, then washed with dish soap and water. After it was dry I went over all the to-be painted surfaces with rubbing alcohol. Krylon semi-flat in a spray can seems to stick just fine on the center console bezel. ~Juliet
Old Oct 25, 2001 | 11:29 PM
Edzred72's Avatar
Edzred72
Thanks to all for the tips...I'm off to my workshop once again. :cheers: :seeya :seeya :seeya
To Windshield Trim and Door Panel Bezel Paint?
