77 speedometer transmission end
Old Jun 11, 2007 | 10:48 PM
yoitslikejohn's Avatar
yoitslikejohn
Default 77 speedometer transmission end
I just picked up my first vette and it has a speedometer that does not function. I have found the problem to be in the transmission end of the linkage. I believe that there are gears inside the hook up for the speedometer cable, but I am not sure. If there is a gear and if that is the problem, what number of teeth do I need for a stock four speed 77?
Old Jun 11, 2007 | 11:30 PM
...Roger...'s Avatar
...Roger...
What is your rear end ratio?
