Q-Jet Electric Choke
Old Jun 13, 2007 | 12:07 PM
TopGunn's Avatar
TopGunn
Default Q-Jet Electric Choke
I had to do away with the perfectly working mechanical choke on my Q-Jet when I switched to this ZZ4 motor so I replaced it with an electric one that's never worked worth a darn. I think the housing with the bi-metalic spring I have is made by Edlebrock, it has the number 3182A on the outside.
I've set it up properly but it only wants to open about 1/2 way no matter how long the engine runs. I'm getting 12volts to the unit ok, I wired it to the wiper motor feed and the mechanical linkage appears to be functioning properly, just seems like the bi-metalic spring inside isn't traveling far enough to complete the job.
Is there anything out there that WORKS RELIABLY that someone could recommend?
Old Jun 13, 2007 | 12:34 PM
jotto's Avatar
jotto
For the 75 Qjet, you need this part,
http://store.summitracing.com/partde...5&autoview=sku
Edelbrock 1932
I have this on my 75 Qjet and when I tested it I think it went from fully closed to fully open in about 1 minute or so,
you have a pm.
Old Jun 13, 2007 | 10:27 PM
TopGunn's Avatar
TopGunn
Thanks jotto, I thought that's what I had, guess not. I looked on the edelbrock site and didn't find any reference to the number on the outside of mine, I don't know what it's supposed to fit then.
Well, if the 1932 works on yours it should also on mine then.
Old Jun 14, 2007 | 04:05 PM
Boofers's Avatar
Boofers
1932 working great on mine as well.
Old Jun 14, 2007 | 11:13 PM
TopGunn's Avatar
TopGunn
Thanks! I'll order one tomorrow
Old Jun 15, 2007 | 08:42 AM
Jims79's Avatar
Jims79
Did you try to adjust the choke lean rich mixture? Loosen the three small screws & turn the black disc towards the radiator when the engine is hot and you should see the choke plate open. then tighten the three screws.
Old Jun 15, 2007 | 09:56 AM
TopGunn's Avatar
TopGunn
Yes I did, then it doesn't close far enough when the engine cools off to provide enough choke. You don't recognize that 3182A number that's on the side do you Jim?? I didn't see it listed on the Edelbrock site.
Bill
To Q-Jet Electric Choke
