"Diesels" when I shut down
Old Jun 14, 2007 | 06:21 AM
Mikeg72's Avatar
Mikeg72
Default "Diesels" when I shut down
Anyone know what causes the car to continue to run after the ignition is shut off? I've adjusted the timing but that doesn't seem to make a difference. Have the idle pretty low (still does it). It's a "72" 454 engine that runs well otherwise but it just wants to keep running.
Thanks!
Mike
Old Jun 14, 2007 | 07:14 AM
Matt Gruber's Avatar
Matt Gruber
should be in gear when it is shut off.
WOW that was easy!
Old Jun 14, 2007 | 07:20 AM
lightning30's Avatar
lightning30
Lol yah that was easy and should stop your problem
Old Jun 14, 2007 | 08:52 AM
Mikeg72's Avatar
Mikeg72
Default Reply
So, you're saying I should have the car in gear and use the clutch to stop the engine? I've had plenty of manual cars but never had one that required that to shut it down.
Old Jun 14, 2007 | 08:57 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You shouldn't have to have your car in gear to get it to shut down. You are basically stalling it and not correcting the underlying problem. You said your idle is pretty low. What is it? High idle is the main reason for run on.
Old Jun 14, 2007 | 09:50 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
You mentioned that you have the idle set low. But, do you also have the throttle plates "set low"? If you are running ported vacuum advance your thermal efficiency at idle is crap. This requires more air and fuel for the same rpm. This then requires a larger throttle opening. This then leads to dieseling. (Note the term dieseling. There is no spark ignition required, hence adjusting your timing does nothing when the ignition is shut off.) If you have ported vacuum, change it to manifold vacuum, and then readjust your throttle stop (idle speed) adjustment.
If you already have manifold vacuum, then there are other issues. Let us know what you are running.
Old Jun 14, 2007 | 09:57 AM
Matt Gruber
in 1970 i drove a then new '70 Duster, company car, i did a delivery with it, shut it off in neutral,
well i come back 15 minutes later it's STILL KICKING.
Funny with a co. car. Even so, that could blow the engine, so i put it in gear(stick). FF to C5's i read they rattle bad if left in neutral.
To park u must put it in gear, right? so shut it off, take foot off clutch. This is hard?
or switch to EFI, that works for sure every time.
Old Jun 14, 2007 | 10:01 AM
jude's Avatar
jude
Have you tried a higher octane fuel? Also; does it have the soleniod on the left side of the carb at the throttle? On my 71 it controls the idle and shuts the throttle plates closed when you turn off the key, but this may be on non a/c cars only.
Old Jun 14, 2007 | 10:13 AM
Mikeg72's Avatar
Mikeg72
Default Reply
You guys are great! Thanks for the help..
I'm running a stock Rochester Quadrajet Carb, no solenoid on the side. I advancd the timing while installing a new distributor and it did increase the idle speed. I'll lower the idle to 800-1200 rpm and
see if that helps.
Thanks for all the input.
Mike
Old Jun 14, 2007 | 11:08 AM
69427's Avatar
69427
I'm running a stock Rochester Quadrajet Carb. Does ignition timing have anything to do with it? I recently replaced the distributor but I don't see how that could have any effect on it.
Mike
Re-read my earlier post. I already answered these questions.
Old Jun 14, 2007 | 12:15 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
see if that helps.
Mike
If you are "lowering your idle to 800-1200 RPM's" that tells me you must be way too high now. Your idle with a 4 speed in neutral should be in the ballpark of 700-800 RPM's.
Old Jun 14, 2007 | 03:16 PM
hdpete98's Avatar
hdpete98
Default Timing
Try retarding the timing 1-2 degrees.
If timing is to far advanced it will run-on.
Old Jun 14, 2007 | 03:31 PM
weimer20's Avatar
weimer20
Just a thought.... check your spark plugs and make sure they are not loaded with carbon. If they are, that carbon will glow like a cherry and provide another source for ignition aside from normal spark.
Old Jun 14, 2007 | 06:17 PM
Mikeg72's Avatar
Mikeg72
Default Problem Solved
Thanks folks,
I drove to the local Sunoco gas station and put 1/2 tank of 260 in it (highest octane they have). And, lowered the idle way down and it shuts off fine now.
Thanks for all your thoughtful help!!
Mike
Old Jun 14, 2007 | 06:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Incorrect timing will cause diesling and here is how, if the timing is retarded then the idle speed will go down, now you turn the idle up to compensate and now the throttle blades are open to far when you shut off and you deisel
To "Diesels" when I shut down
