UFOE! (Unidentified Fluid On Engine!)
Old Oct 26, 2001 | 12:51 PM
VolVette's Avatar
VolVette
Default UFOE! (Unidentified Fluid On Engine!)
Over the last few weeks when I open my hood and work my my '75, I notice small red spots of dried fluid on the front of the driver's side valve covers. The fluid looks to be of a light riddish tint. I am not sure where it could be coming from but because there is usually some on my heater hose and distributor, I keep thinking that it could be from my radiator and the fan is blowing it back?
Have y'all ever heard or seen something like this and have ideas of what it might be?
Thanks,
Stephen
Old Oct 26, 2001 | 12:55 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: UFOE! (VolVette)
what coolant are you using.
I run 100% distilled water and water wetter. When a puddle of that is left, the water evaporates and leaves a little red stain from the water wetter.
My only guess.
Old Oct 26, 2001 | 12:57 PM
rainman69's Avatar
rainman69
I've got some small spots of red fluid on my engine as well...except mine is blood. :eek:
The car ate :reddevil a squirrel a little while ago while I was underneath. I hate squirrels now. :boxing :mad
But I don't think that helps you. Do you have an auto? PS? That new orange antifreeze? Those would be the first places to look for leaks.
[Modified by rainman69, 9:58 AM 10/26/2001]
Old Oct 26, 2001 | 01:05 PM
JME's Avatar
JME
How about rust from a water leak?
Old Oct 26, 2001 | 01:20 PM
MELVIN's Avatar
MELVIN
Default Re: UFOE! (JME)
COULD BE RAD FLUID FROM THE WEEP HOLE IN THE WATER PUMP FLINGING BACK FROM THE FAN. OR PB/PS FLUID.
WHATS IT SMELL LIKE (IF YOU CAN)?
Old Oct 26, 2001 | 01:22 PM
MELVIN's Avatar
MELVIN
Default Re: UFOE! (MELVIN)
AFTER YOU DRIVE, LOOK CLOSELY UNDER YOUR WATER PUMP FOR A DRIP (WAIT ABOUT 30 MINUTES FIRST). ALSO, INSPECT THE WEEPHOLE AREA. WEEP HOLE LEAKAGE TENDS TO SHOW WATER PUMP IS WEAR, AND IS READY TO GO SOUTH
Old Oct 26, 2001 | 01:39 PM
john's '81 mouse's Avatar
john's '81 mouse
Could it possibly be power steering fluid leaking out of pump and being slung around engine compartment by centrifical force and air movement?
Old Oct 26, 2001 | 02:07 PM
70PurpleLS7's Avatar
70PurpleLS7
If you have an automatic, and you say it's coming from the radiator, check your lines from the tranny to the radiator, maybe you have a small leak developing under pressure..
Just my .02..
Old Oct 26, 2001 | 02:34 PM
VolVette's Avatar
VolVette
Default Re: UFOE!
I have not smelled it, usually because it dries on the valve covers before I have a chance. The color most makes me think it's coming from the radiator but it certainly could be something else because it's also close to the color of ATF. So, yes, I do have an automatic as well.
Old Oct 26, 2001 | 03:36 PM
Wrencher's Avatar
Wrencher
Power steering fluid and ATF won't "dry" and they tend to make a BIG mess, leak while idling, and are generally on the drivers side. If the waterpump is leaking (my guess), the fluid is coming out of the vent under the pulley (it is between the front and rear waterpump bearings) and the pulley with some help from the fan is throwing it back against the engine/ hoses/ whatever. You can't see it from the top, but if you jack the car up, it is visible from underneath and WILL have a stain.
Hans
To UFOE! (Unidentified Fluid On Engine!)
