Tri Power Setup Question
Old Jun 19, 2007 | 05:06 PM
  #41
HaulnSS2's Avatar
HaulnSS2
Originally Posted by DWncchs
Get your end carbs closed up and out of the picture temporarily.Then adjust center carb curb idle and idle mixture screws.Treat it like a 2 barrel until you get that part solved then bring in the other 2.
Will do, wish me luck!
Old Jun 20, 2007 | 12:32 AM
  #42
RPOL68's Avatar
RPOL68
Here are some pictures of a vacuum leak source if you use the wrong base gasket. First photo shows that PCV passage in the manifold. Second photo shows a wrong base gasket. I'm referring to the outside edges, not the bore edges. You can clearly see the open passage but with the center carb on you can't see it. You just have a vacuum leak as thick as the gasket is which is substantial.
Old Jun 20, 2007 | 07:57 AM
  #43
...Roger...'s Avatar
...Roger...
That would create a big leak !!!
That was nice of you to go out and take your car apart to show the leak you were talking about.
Old Jun 20, 2007 | 11:09 AM
  #44
HaulnSS2's Avatar
HaulnSS2
I appreciate the help guys, getting ready to start working on it again.
Old Jun 20, 2007 | 12:02 PM
  #45
RPOL68's Avatar
RPOL68
I ran with this leak for years (and a pinging problem) before I discovered it. I've related the story so many times that I took photos that last time I had the center carb off and kept them on file.
Old Jun 20, 2007 | 12:13 PM
  #46
WESCH's Avatar
WESCH
Hi
That leak looks big , but once the center carb is mounted, is probably rather small, only the thickness of the paper gasket or less.
Günther
Old Jun 13, 2012 | 08:47 PM
  #47
mcolvin's Avatar
mcolvin
6th Gear
Default tri-power center base gasket
I have read that all three base gaskets on the 427 holley tri-power carbs are the same .06 thickness. I don't see how the paper .06 thin gasket can hold up very long on the center carb. The vacuum chanel will surely suck it in and tear it. Surely the correct center carb base gasket is thicker and made from a composite material. I had a vacuum leak and sure enough the paper thin center carb base gasket was tore at the vacuum chanel. Does anyone know where to get the correct center carb base gasket?
Old Jun 14, 2012 | 05:55 PM
  #48
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
i'm a bit lost trying to follow the problem here. Should the gasket cover the entire channel ? can someone supply a "CORRECT" gasket to compare it to ? can't see exactly whats wrong here ???
Old Jun 14, 2012 | 06:19 PM
  #49
...Roger...
The gasket needs to cover the entire channel,otherwise air will be sucking in through that small opening. Once the carb is in place the opening will only be the thickness of the gasket but it is enough to cause a problem.
Old Jun 14, 2012 | 07:13 PM
  #50
jetjockey's Avatar
jetjockey
Originally Posted by WESCH
Hi
Multi-carb setups are notorious for being a pain to properly adjust.
Right, but this does not count for the original Vette tripower setup.
Only the ctr carb has a idle feature, the 2 2ndaries only come in on power. Idle setup is as easy as on a ordinary Holley 4150.
Carb rebuild, choke fully open and nor vacuum leaks and it just works fine.
Günther
People that have problems with them have issues with the components. Warpage, old leaking gaskets, blown power valves, cobbed together Holleys, poor ignition systems, worn out motors. With everything in proper working order they are no more difficult than any other setup.
If not, they are just as bad as any Q-jet or Holley 1x4.
Dan
