71 Spindle Support Question
Old Jun 16, 2007 | 07:55 PM
n.g.hayes's Avatar
n.g.hayes
Default 71 Spindle Support Question
Feedback really appreciated on this question. I know the 71 vets have a left and right rear spindle support on each trailing arm. I also know the shock support goes in one direction only with a flat area cut in one leg to position this support. Other than this easily visible difference, I can find nothing else different from left to right supports. I can overcome the shock mount difference very easily if they are switched from left to right. Laying them side by side, I see no other difference. My question is this, can you use a right on the left and a left on the right? I can hear it now, why would you want to do this? Long story, don't ask!
Norm
Old Jun 16, 2007 | 08:14 PM
...Roger...'s Avatar
...Roger...
Norm
No !!!
Old Jun 16, 2007 | 08:55 PM
GTR1999's Avatar
GTR1999
Flat hole goes to the rear of the car or else the the mount will not be in the correct orientation.
PM me and I'll direct you to some pictorials.
Old Jun 16, 2007 | 09:25 PM
...Roger...
Hmmm maybe I was too quick to say no.Gary are the castings the same right and left?Years ago I thought I noticed that the angle of the strut mount was different.In other words if you swapped sides it would be drasticly different at the strut mount.I dont have any seperate or I would compare-all mine have arms on them ready to go on the car.
Old Jun 16, 2007 | 09:41 PM
big_G's Avatar
big_G
The flat is only on the rear ear and the front ear has a round hole, making them lefts and rights only.
Old Jun 16, 2007 | 11:35 PM
n.g.hayes's Avatar
n.g.hayes
Like I stated in my question, yes, the holes are different for the shock mounts. That can be corrected with some simple machine work on the shock mount bolt itself. My main concern is any other difference in the spindle supports that I may have missed. They both look the same to me.
Thanks,
Norm
Old Jun 16, 2007 | 11:47 PM
big_G's Avatar
big_G
I think I know what you want to do, but the end of each shock mount is knurled to fit tightly in the support. I have seen worn out mounts that would rotate with the shock movement. The tight fit is necessary to prevent rotation. Other than that, I think they are symmetrical.
Old Jun 16, 2007 | 11:58 PM
n.g.hayes's Avatar
n.g.hayes
I have a very tight fit so that should not be a problem. My main concern was something that may alter the geometry of each trailing arm and cause an alignment problem when this beast hits the road again. I have put a left and right on a flat surface and checked every angle possible and came up with no differences. It is always comforting to get a second opinion. I hate to pull all this apart and start over. Trailing arms are a pain in my butt.
Thanks for the all the info.
Norm
Old Jun 17, 2007 | 05:46 AM
BB72's Avatar
BB72
Norm
I see your problem....they are the same except for the differences you pointed out. I don't see how your going to use the shock/strut mount without it spinning . Thats assuming you plan on taking the flat spot/key out of the bore of the support ear to fit the mount in the other way. If you have a good solution...lets hear it.
Old Jun 17, 2007 | 07:40 AM
...Roger...
Norm
Geometry-thats the word I was looking for !!! I had it in my mind it was different right and left BUT after looking at the casting marks I think you are correct they are the same except for the shock mount.
It looks like you could weld it up and remachine and turn a right into a left and vise versa.
The half a$$ way would be to flat the shock mount all the way to the shock end and remove the knurl.On the nut end fill the large hole with a bushing setup to take up the slop.The flat in the support will be doing all the anti rotation work.
Sorry I spit out a quick NO- I understood your question but truely thought the casting itself was different.Good Luck and let us know how it turns out it will be nice to know for sure after the car is aligned.
Old Jun 17, 2007 | 08:26 AM
n.g.hayes's Avatar
n.g.hayes
Thanks to all. You have put my mind at ease. Yes, I will certainly let you know how the alignment works out. The shock mount is a simple fix with some precision cutting and grinding. The adjustable strut rods hooked up with no problem.
Thanks again,
Norm
To 71 Spindle Support Question
