Believe it or not, that's exactly what you use. You might have to search for it. It comes in packs of several pieces and are about 10" long. Check auto parts stores and machine shops.
So when we reinstall rotors, and shim them to eliminate runout. What do you use for shim stock?
hehe, being a cheeeeep bastard.....aluminum foil....works fine....make sure you taper it off over several bolts.....say one bolt takes 2 thick, then either bolt on each side gets one thick....etc....
works fine for me....BTW, NAPA rotors on my front end are perfect right outta the box....the rears give the most troubles....
but they are not NAPA rotors....and the rotors are differant front to rear...
for aluminum foil, however many layers, I just knock a hole in it and put about an inch square over the stud or studs...depending...then bolt the rotor down with 3 bolts, leaving the two intermediate bolts off....between the 'high' side and the 'lo' side....so as not warp the rotor with force...maybe spring the metal, and my being cautious I don't wanna....
I used aluminum duct tape. It is a little thicker that foil but a lot stronger plus it is very nice to work with. I like to stick on the backside of the rotor then trim around the bolt holes with an razor blade. Like to above post said, taper it if you are using more than one layer.
Stainless Steel Brake Corporation used to manufacture corvette disk shims in .004 to .015 tapered widths. SSBrakes.com. Part no. 1602 or a-1602, Doesn't show up on thier website, so you'll need to call them. 800-448-7722.
McMaster-Carr has brass shim material. I got a box with different mils (.001-.015 I think ) and it will last a lifetime and works great!
I got some washer-like shims from McMaster-Carr too, I think - catalog is at home. I got the assorted sizes, and should last me quite long also. Takes forever - add shim, re-measure, change shim, re-measure, forget which side is high, forget where to put shim, measure again, add another shim......you get the picture. I tried to get it under .005"
Yup, I've got Tanglefoot beer can behind mine (metal is 0.004" thick). Just used the kitchen scissors to cut 1"ish discs out of it & cut holes in the middle. Worked great & was a heck of a lot cheaper than I was quoted for some shim stock (plus it's a beautiful beer ). If you get grief over blunting the kitchen scissors, just use them to cut a few sheets of emery/wet-or-dry & it'll bring back the edge. You'll need some abrasive to clean up the rust anyway. With 3 shims under one rotor & 2 under the other, I got runout well within spec.
Been on the Forum for sometime and this is the first I've heard of shimming rotors...since I've put all new brakes on my 78 (still not driven)...can someone briefly explain what we're doing here.
In a nutshell, excessive rotor runout will cause the calipers to pump air thereby causing spongy brakes.
