How to pull an engine?
This'll be my first time pulling an engine, and am looking for a pretty detailed, step by step instructions. I've searched the archives and internet to no avail, and was hoping maybe someone had a paper or another source of info, maybe a book I should look into?
Just a basic 4 speed, 350. I've already pulled the radiator as that needed to be replaced, so I have plenty of room. The exhaust manifolds have been removed as well.
attach the pull chains to the motor, and remove...
If you want to pull the tranny then you have more work to do, but it's not necessary to pull the tranny, unless you're going to replace the clutch.
The Corvette Shop Manual and Corvette service manual are also good books but you'll have to order them from one on the sponsors. PG
Then you've got to drain the coolant (which has already been done in your case, go ahead and mark and take out distributor, disconnect accessories (alternator, ps, a/c, etc), take off manifolds/headers (you can just move them to the side, remove plugs, disconnect starter, remove z-bar, take out engine mount bolts, disconnect carb, fuel line, and throttle linkage and I usually remove carb, disconnect any wires like water temp lead on head and oil pressure line on back of block.
Now you need to decide if you're pulling engine and tranny or just engine. I like pulling it all cause it's hard to get to the bellhousing bolts and hard to get to the transmission mount bolts when it's all in the car. So I disconnect driveshaft, tape the yoke to the tailshaft with duct tape, disconnect shifter linkage, disconnect speedo cable on transmission, backup light, tranny mount bolts, etc. From there you're pretty much ready to pull it. I take the passenger wheel off and position my engine lift coming in from the side. Remember you have to come up and forward a bit before it comes over and out so make sure your jackstand isn't going to be in the way of the engine lift leg. The c3 nose is a bit long so you really can't pull it from the front. You might also want to tape/plug up water pump outlets if you still have water in the block. You could also remove the water drain holes and drain the water but sometimes those are hard to get to while in the car.
Here's some pics of my last BB install: http://www.nwhoustonvette-rods.com/T...7Install1.html
Is this little project a PITA? How much time am I looking at? Should I expect it to pop right out or will it need some work? Where are the big problem areas?
I'm trying to find something detailed, possibly with pictures, maybe even some tips.
I'd recommend using an engine puller with a screw type leveling mechanism. You can really move the engine around and it's easier to manipulate. Another thing that's not mentioned often is how to attach the chain (or chains). The best way might be to get a set of those lifting loops or your engine might already have them. A cheaper way is to get a good strong set of bolts and washers. Pass them through the chain then screw them into the ends of the heads. If you decide to use a carb attachment plate to lift, then the leveling mechanism won't help. The engine will just have to come out at whatever angle it wants to...
Make sure everything is disconnected and start lifting slowly.
I just bought the book Haynes Techbkook Chevy Engine Overhaul Manual. Supposedly there's detailed instructions in there on pulling the engine. Anyone use this book?
I'm at work now so I can't look at it, but did you mean screw two eye loop bolts into the manifold? I've never seen any loops on the manifold.
Make sure you remove the ground wire from the engine to the frame. I forgot and was raising the engine and couldn't figure out why it was being so difficult. I saw the cable. When I removed the bolt from the block the car dropped an inch or so and the engine began bobbing up and down on the end of the hoist.
Check out my website www.thespark.us for some pics.
BTW, I removed the intake and exhaust manifolds to reduce the weight as much as possible. A 454 is pretty heavy.
Can you rent the leveler when you rent the hoist? Or will I have to go and buy a leveler?
your heads have accessory bolt holes at the end of the heads, use those to attach the chains or you can use the exhaust bolt holes either way it will work.
The other rope I needed to keep it from rotating while I took the photos....
It is a little difficult if you do this all by yourself.....
