About a week ago I had the left rear wheel bearing go out. I have rebuilt both trailing arms. The bad wheel bearing almost fell out, Had the spindels checked. Both OK. I rebuilt both trailing arms with the help of GTR1999. Gary was a big help. His instructions helped me walk through the backlash setup. I replaced all 4 universals, and all of the bushings.
Now to my problem. I want to replace all of the rear end fluid. I cannot get the fill plug to move. The square plug is going to round off If I continue to try to move it. I have let it soak in PB Blaster and will continue to try on the round portion of the filler plug. Does anyone have any bright Ideas?? This forum and it's members have helped me out in the past. You are a great bunch. Is the rear end Aluminium???
If so it has probably siezed. Always use anti-sieze. Thanks
You know, it would be nice if you folks would say what year car you are asking about. If it is the `73 thats in your profile, then, no, its not aluminum. Are you using a correct square 8 point socket to get the plug out?
4 point socket--Buy one! Or if your car is drivable go to a quick lube and ask them to loosen it for you.Its a taper thread so I doubt if PB will do anything its pretty well lubed on the inside.
Reason: spelling
If the 5/8, 4 point dont turn it, might want to consider removing the spare tire carrier and use a small pipe wrench on the round portion. Along with a large hammer.
Tack Weld A Nut On The Drain Plug
The Heat Will Help Break It Loose
Don't Get Carried Away - Just Tack It In Place
The Drain Plug Is Steel , After It's Out
Buy A New Drain Plug - I Have Done This
Many Times, It Works!!!
You could also put some penetrating oil on it and let it set for a day.
Yes it is a 73. Sorry about not stating that earlier. I did remove both parts of the spare tire holder. I will buy the socket today and if that does not work I will tack a nut on and try that. Thanks for all of the good advise. This forum is great.
One way that should work but will require soe extra time.....
Drop the spare tire holder, remove the spare, remove the spare tire holder from the car (two bolts) and then you have great and clear access to the diff fill bolt....you can place a rachet on the bolt and use a two or three foot pipe wrench over the rachet to gain the leverage to reove the stubborn bolt. I did this and it worked well.
Just be catious when placing the bolt back in as it's easy to crossthread and tighten the bold down before you re-install the spare tire cover. However, I'll be honest....its a PITA to remove the diff fluid with a siffon. Take your car to a decent shop and they have vacum pumps to get all the fluid out and may even do the job for $25 if you call around. Be sure to use posi-slip gear addative when you replace the fluid. YOu can buy some off the shelf at the auto-store or go with GM brand.
If you get the pump that goes on a gallon jug, you can add a piece of tube to the part that goes in the jug and use it to pump out the old oil then put it back on the gallon jug to pump in new oil works much, much, much better than a siphon pump i have both trust me the one that goes on the gallon jug makes it a piece of cake!!!!!!!!!
Don't understand --- can you explain this better ????
Local auto parts store has these pumps, the gallon jug does not come with the pump, a old windshield washer fluid jug works good, just replace the short hose that goes inside the gallon jug with a longer piece of hose to remove old oil.
If you're replacing the fluid and its very old, you may want to also replace the gasket. This will allow you to get all the fluid out. If you don't do that, the pump is a must.
