[DIFFERENTIAL] Critique my pattern?
Old Jun 19, 2007 | 10:59 PM
Ken73's Avatar
Ken73
Cruise-In III Veteran
Default [DIFFERENTIAL] Critique my pattern?
This is on my '82 diff, so it's not quite exactly like the '63-'79 diff, but pretty much the same.
Backlash is at .009" - within the .008"-.010" spec. Pinion is moved up slightly from where it was for spec, will have to measure to be 100% sure by how much. Took me about 5 or 6 tries to get it to this point. Was too far up & out originally, got it in & down to this point now.
Drive side..
Coast side..
Old Jun 20, 2007 | 12:24 AM
Retro78's Avatar
Retro78
I cannot tell from the paste type that you are using. What is that? GM has the good yellow stuff that will really show the pattern.
Old Jun 20, 2007 | 01:14 AM
Ken73's Avatar
Ken73
It's the white paste that came with the kit. Where can I get the yellow stuff?
Old Jun 20, 2007 | 08:37 AM
GTR1999's Avatar
GTR1999
Drive side is deep. Coast looks close and to heel. You need to go with a thinner shim and load the gears as you pattern them. Thin out out the paste and get the yellow paste from any GM dealership.
Old Jun 20, 2007 | 10:06 AM
Ken73's Avatar
Ken73
Drive side is deep - on the root..? Thinner shim on the pinion?
I do load the gears when I pattern them - this grease sucks. I'll see if I can find a GM dealership for the yellow stuff. What should I ask for?
Old Jun 22, 2007 | 10:40 PM
SmokinBBC's Avatar
SmokinBBC
# 1052351 is the Part number for yellow GM marking compound.
Old Jun 24, 2007 | 10:37 AM
Ken73's Avatar
Ken73
Got the yellow stuff at the dealership just the other day. Here's the results (though I can't tell much difference from the white stuff?) Am I doing something wrong? I'm loading the case up while I turn the pinion.. or do I turn the case while I load the pinion?
Drive side..
Coast side..
Old Jun 24, 2007 | 12:58 PM
SmokinBBC's Avatar
SmokinBBC
The pattern is much more "readable", but you need to clean that white crap off. Looks deep as Gary said. He wants you to put in a thinner pinion shim. What is the shim size that you are using?
Here is a link to Gary's post.
http://forums.corvetteforum.com/show...1236684&page=2
See the pinion shim in post 19 and pattern starting with post 24.
Is this a new set of gears? Or are you trying to reset an existing set after a fix of something? If it is the existing gear, did you do a pattern before taking it apart?
Old Jun 24, 2007 | 01:43 PM
Ken73's Avatar
Ken73
New gears. Went from stock 2.87 to 3.23.
I'll disassemble and clean all the white crap off real good - might be a week before I can get back to it though, leaving out today for Virginia for the week.
I'll pull out some pinion shim, I've done it about 4 or 5 times already to get this result as it is. I thought you wanted it closer to the middle (heel to toe?)
Old Jun 25, 2007 | 08:32 AM
SmokinBBC's Avatar
SmokinBBC
What size shim you have in there now?
It is more important to have it centered between the face and flank.
Try PM to GTR1999 or TRACDogg2.
Old Jun 25, 2007 | 11:16 AM
68 NJConv 454's Avatar
68 NJConv 454
If my understanding is correct you have to load the pinion and turn the ring gear. Take a thick leather belt and wrap it around the pinion for load and then use a closed end wrench on the ring gear bolts to turn the gears.
I beleive your drive side should be more on the toe (inside) of the gears than the heel (outside). As you drive the car the gears will break in and the pattern will then cover the entire gear face. When setting it up your pattern should cover the full half of the gear toe.
Your coast side doesn't look too bad except you want it to leave a rectangle pattery not a triangle pattern like you have.
I can see the shiming, disassmble, reassemble of the diff the most frustrating rebuild on the car.
Don't ask me about shims. I only learned this stuff this weekend.
Definitely PM GTR1999 or TRACDogg2 like SmokinBBC advised.
Old Jun 25, 2007 | 04:37 PM
SmokinBBC's Avatar
SmokinBBC
Here is a pic from West Coast Differentials of acceptable patterns.
Old Jun 25, 2007 | 05:01 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Old Jun 25, 2007 | 07:08 PM
comp's Avatar
comp
Originally Posted by TheSkunkWorks
Old Jun 26, 2007 | 12:39 PM
SmokinBBC's Avatar
SmokinBBC
Use some brake cleaner to clean off the marking compound when you have it dissasembled.
Old Jun 26, 2007 | 08:59 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I bet Dollars to Donuts that if you measure the old pinion shim and install the same thickness on the new gear and set your backlash to .006
Your pattern will be good.
Give that a try.
If you were close I'd swing by and get you dialed in.
TO load the gears use the wooden handle of a hammer against the ring gear and turn the pinion by hand in the fwd direction,yoiu dont need alot of pressure just a good drag.
Thinning the marking compound with just a drop or 2 of oil helps also
Whos gears are you using?
Old Jun 27, 2007 | 03:13 PM
Ken73's Avatar
Ken73
Using Precision Gear gearset. Got back early from VA, will probably work on this tomorrow. I'll measure everything and clean during disassembly. Thanks for the tips so far! I was loading the carrier just with my hand, so I'll see if I can put some more pressure on it.
Old Jun 27, 2007 | 06:24 PM
pws69's Avatar
pws69
Originally Posted by pmullaly
I bet Dollars to Donuts that if you measure the old pinion shim and install the same thickness ........
To initially get as close to the original settings (i.e. pattern), you do have to factor in the measurement inscribed into the front/face of the pinion gear then use the appropriate thickness "shim" - it will probably be a little different size than the original.
To [DIFFERENTIAL] Critique my pattern?
