TH400 Trouble....
Old Jun 22, 2007 | 02:34 PM
Wisp's Avatar
Wisp
Default TH400 Trouble....
Hi...
I have some trouble with my Transmission.
It is haveing trouble shifting automatic, and the car are missing ALOT of power. Sometimes the are som vibrations from the transmission.
It all started suddenly. It was missing alot of oil becourse I had a lose pipe to the cooler.
I have put oil to the mark again.
Checked the modulator.
And the kickdownswitch is activated when I go full throttle....
But the problem is still there....
Did I blew my transmission?
Any suggestions?
Best regards Wisp
Old Jun 22, 2007 | 02:39 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
you sure its full of fluid? check hot while engine running Trans in park or neutral.
make sure Vac modulator is hooked up
Old Jun 22, 2007 | 02:44 PM
Wisp's Avatar
Wisp
Yep the oil is right on the mark.....
Removed the modulator and sucked on it.... It´s not leaking and the pin moves inside....
Wisp
Old Jun 22, 2007 | 04:34 PM
S489's Avatar
S489
could be possible internal damage to tranny, especially if loss of fluid to pump was long enough . . .
Old Jun 22, 2007 | 04:50 PM
Wisp's Avatar
Wisp
Anyway to check without removing the tranny...?
Know **** about tranny.....
Wisp
Old Jun 22, 2007 | 06:31 PM
AzMotorhead
Service manual show where to hook up a pressure gauge and what readings should be
Old Jun 22, 2007 | 06:37 PM
Wisp's Avatar
Wisp
Only got: Owners manual, AIM and the Haynes
Could it be the converter?
Wisp
To TH400 Trouble....
