Oil Pump Gasket????
Old Jun 22, 2007 | 09:42 PM
blueonblue's Avatar
blueonblue
Default Oil Pump Gasket????
I ordered a new Melling Select oil pump and thought it a little strange that it came with no gasket. Went to the local NAPA and they said they only showed a oil pump gasket for a Corvette thru 1977. Finally they said they found the part, but it would have to be ordered from Seattle, Wash. They sent me next door to a high performance parts shop and after telling them my situation, they explained that the Chevy oil pump does not require a gasket. I checked the Hayes Manual and it did not mention it at all. Anyone know how the pump goes on? With gasket or without? As always, thanks in advance.
Old Jun 22, 2007 | 09:52 PM
speedreed8's Avatar
speedreed8
i replaced the eng. bearings in my 79 L82, in the car, the oil pump had no gasket when i pulled it. i just put some permatex gasket sealer on it and reinstalled new one. have over 2000 miles on it since. and oil pressure maintains at 45 psi.
Old Jun 22, 2007 | 10:37 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No gasket...no sealer. It's a machined surface and seals fine. If you put sealer on it you're asking for it to go straight to bearings.
JIM
...Roger...'s Avatar
...Roger...
No gasket-No sealer
Old Jun 22, 2007 | 11:16 PM
Ironcross's Avatar
Ironcross
JIM
It cant be stated any better than this.,,,,
Old Jun 22, 2007 | 11:28 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I am glad to hear that.....had me worried for a second there!
My 454 had no gasket.....before or after I replaced it!
Old Jun 23, 2007 | 01:19 AM
blueonblue's Avatar
blueonblue
Thanks for all of the input. It puts my mind at ease.
Old Jun 23, 2007 | 07:32 PM
Richard Cooper's Avatar
Richard Cooper
I too put a new oil pump in my 81 with NO gasket.
Old Jun 23, 2007 | 07:34 PM
GTR1999's Avatar
GTR1999
You might want to check the gears for burrs and tack weld the pickup tube once it's set to the correct height.
To Oil Pump Gasket????
